Www.dynamite.com might still sell what you want :> Just kiddding!
Try a complete wiping of the hard-drive unless you are doing an upgrade, you will lose all data on the drive. If that doesn't work, you might not be running enough ram memory for 7 to run cleanly on you machiine, go ahead and upgrade.
Hope this helps!
SOURCE: Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
SOURCE: Emachines W3052 Gets stuck on logo screen when starting up.
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
SOURCE: Emachine locks on windows splash screen
Try flashing the Bios, if this does not work you may have a processor problem or a problem with the operations of the northbridge or southbridge not functioning correctly causing the freeze problem.The only repair for this type of problem is to replace the motherboard. If the computer is over three or four years old this may be the situation. You should check the condition of all the processors before giving up on the board.Try removing the heatsinks and reapplying the thermal paste. Make sure to clean all dust and debris form the processors. Make sure all the heatsinks are making good contact with their processors. Be sure to clean all dust and debris form the inside of the case and under the motherboard. Check all the screws and standoffs, Just or make sure you are not having shorting problems between the motherboard and case. Hope this helps you with your problem.
SOURCE: Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
SOURCE: error unitialized corrupt boot structure detected
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
