20 Most Recent
Curtis CM19033S 19" TV Questions & Answers
Curtis LCD2425 screen is white
Chroma decoder IC has failed. Repalce it with same type and number. check the video output supply voltage comes to CRT base board too.
Looking for the cable code, i have dish network
Hello, here are some simple steps to follow to get this working!!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
680
500
830
If these codes don't work, try these steps:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
If neither of these steps work, post back the model of the remote, (which you can find on the back at the top, it is a 2-3 digit number, like a 3.0 or 21.0) and there may be codes that work better for your particular remote. Hope this helps!
Becki Barned
DISH Network Customer Service
I get channel until #13
TV's of this era have two modes that the tuner can work in. One is the AIR mode and the other is CABLE. In the air mode the tuner picks up only "off air" frequencies,... and up to channel 13 they happen to be the same as cable channels 2 thru 13. If you are using cable you will need to go into your on screen menu and find where to change the tuner from "air" to "cable" to get channels above 13. Older sets had a switch on the front and sometimes the back to select the tuner mode.
I have a Curtis LCD1922A and it comes on and has
The ballast transformer of the cold cathode on your monitor is overheating.. Replace this..If the monitor is on and keeps on changing from white screen to black. The cold cathode light is almost up. Replace this one too.
TV Reset Problem
trying setting it on fire, let it burn for about a half hour then come back to it. should work like a champ then
No sound - Great picture
Sounds like something in the sound output quit. If this is a very old set, it might be time to part ways with it.
Greg.
Where do I get the firmware for Curtis DVD playere
To get the firmware for your Curtis DVD player, you will need to contact the manufacturer or visit their website. The firmware is the software that runs on the DVD player and controls its functions. It is important to keep the firmware up to date in order to ensure that the DVD player is operating properly and to take advantage of any new features or bug fixes.
To get the latest firmware for your Curtis DVD player, you can try the following steps:
- Visit the Curtis website and navigate to the support or downloads section. Look for a section that lists firmware updates for DVD players.
- Download the latest firmware update for your specific DVD player model.
- Follow the instructions provided by the manufacturer for installing the firmware update. This may involve creating a bootable USB drive or inserting a CD into the DVD player.
- Once the update is installed, restart the DVD player to complete the process.
If you are unable to find the firmware on the Curtis website or if you have any difficulty with the update process, you can contact the manufacturer for assistance. They may be able to provide further instructions or assistance.
Curtis TV, Mod#LCD2443A: Picture died, Sound is OK. Which part needs replacement - Mother-board or sub-components? Is it a big job, or simple plug-in swap? Any cautionary info?
Thanks.
Dave
What way you think, working with an LCD TV is skilled work indeed. Here, as sound is OK, there should be something wrong with its picture circuit of the main board. You should have skill in working with main board of an LCD TV. If you haven't it will be best to contact any service technician.
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Always respect voltages. While some may not be dangerous in themselves, they can cause unexpected reactions that are best avoided. Before reaching into a powered TV set, it is best to test the high voltage insulation. It is easy to do, and is a good service precaution.}
Curtis mathes tv model# v37ncgi blinking red light do to have a diaogram of where capulators are located?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box...
