Televison & Video Logo
Question about Curtis Televison & Video
How to upgrade curtis blueray play firmware?
Posted by San James on
Muhammad Zakria
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
To upgrade the firmware on a Curtis Blu-ray player, you will need to follow these steps:
  1. Check the manufacturer's website to see if a firmware update is available for your specific model of Curtis Blu-ray player.
  2. Download the firmware update file from the manufacturer's website onto your computer.
  3. Connect a USB flash drive to your computer and create a folder on it named "CURTIS."
  4. Copy the downloaded firmware update file into the "CURTIS" folder on the USB flash drive.
  5. Unplug the USB flash drive from your computer and plug it into the USB port on your Curtis Blu-ray player.
  6. Turn on the Blu-ray player and navigate to the "Settings" menu.
  7. Find the "Software Update" or "Firmware Update" option and select it.
  8. Follow the on-screen instructions to complete the firmware update process.
Posted on Dec 30, 2022
Play my dvd's
The Region setting maybe incorrect.
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blueray that allows you to play Bluerays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Panasonic blueray player won't turn on after firmware upgrade
Unplug player from wall receptical and unhook the remaining attachments, press and hold power for at least 2 minutes to reset the processor, if this fails, go to www.panasonic.com contact customer support and the technical department.
1helpful
I have a acer 6920 and have problem playing blueray dvd
Newer BR disks are in an different format. If you can't view them then either you need a new BR unit or you need to upgrade the firmware of the one you have - if this is possible.
It freezes when playing a blueray movie. it seems
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. Most often, the firmware problem is JAVA related and will not let the menus load at all, but freezing during playback has also been reportedly fixed with the firmware upgrade.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Paystation 3 repair
have you tried upgrading the firmware
Wont play the music
This may be caused due to damaged firmware but can be recovered by firmware upgrade. Click on the link given below to download the Firmware folder on your computer. When done, refer to file "procedure.doc", a Word file included in the Firmware folder, and follow the procedure to upgrade the Firmware of MP3 player. Download the Firmware folder at http://www.curtisint.com/html/custservice/manuals/CUR_MPS1015_FW-UPGRADE.ZIP
Curtis mps515 player
There are many possibilities. Here is one:
3answers
I just bought the Curtis MPS515
The Curtis site says that a Firmware update is required for this product. The firware update fixes a welcome screen as well as the computer not seeing the device issue - see download site in reply pasted below...
Q: When turned on, The WELCOME screen goes on but the unit shuts down after that even with new battery.
This may be caused due to damaged firmware but can be recovered by firmware upgrade. Click on the link given below to download the Firmware folder on your computer. When done, refer to file "procedure.doc", a Word file included in the Firmware folder, and follow the procedure to upgrade the Firmware of MP3 player. Download the Firmware folder at http://www.curtisint.com/html/custservice/manuals/CUR_MPS515_FW-UPGRADE.ZIP
Q: The computer does not recognize the MP3 player.
Upgrade the Firmware of the MP3 player, as procedure explained above.
Top Curtis Televison & Video Experts
Mike
mark warfield
mark warfield
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
