20 Most Recent
Adidas 2G Pro Low Basketball Shoe for Men Questions & Answers
Hi there! Have you tried the adidas Men's Pro
I am very pleased with these basketball shoes. They have great ankle support.My feet feel very secure and stable inside the shoes.This is the second pair of Adidas basketball shoes I've owned, and I love them. Highly recommended.
THE CLIP IN ARM HAS
hi
i dont think it will be a problem .first check out if your sunglasses is in waranty period if it is then just approach the authorized dealer he will get it replaced if it not in warranty . then just approach the dealers who deal with branded sunglasses they get it replace it may costa little but then knw what arm suit exacty your sunglases. i shall give you site to refer it may help you
Shoe for high arches for muay thai
check with your doctor who may give you pills for muscular relaxation usually used by sportsman and woman i know the name but i cannot recomment here as i am not a doctor.
Consider a compressed video
Looking at your problem it does not appear to be a shoe problem but an ATM network problem. This question has not been answered because it is under the wrong category so the wrong experts are looking at it. If you try changing the category to something more similar then you have a better chance of getting a helpful answer back.
Any thoughts on Allen Edmonds Men's Copley Plain
Finally gave in and bought my first pair of real shoes. The material and workmanship is excellent and they are comfortable. They look sharp and I've gotten compliments for it. I wear them all day Sundays and other times when a suit is appropriate so I get good use of them. They're very easy to take care of. Just a warm damp cloth will clean them up. No need to ever shine them at all.
I've started practicing two weeks ago. I'm running
I honestly didn't consider adidas running shoes before trying adiSTAR Ride 2.0 on at my local running shop. I wasn't sold. I went online, did a bit of research on the adidas shop, bought a pair (thanks for the free shipping!), and couldn't be happier.
I run 4-5 times a week, about 5-8 miles each go. I used to run in Asics and, if I'm being honest, my feet hurt afterwards.
The adistar ride is fantastic! stability is great. I feel like I'm running on air. And the climacool fabric keeps my feet from overheating. I will probably buy a second pair or even a third one - please, please don't change this product. Pricey? Not really when compared to other better running shoes. I couldn't be happier.
If you want great value for your money, buy these shoes! They do run about a size small, so order up.
Oakley screw fell out
Here are a few steps you can take to address this issue:
Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws.
Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design.
Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits.
Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM •
Clothing...
Answered
on Apr 20, 2024
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
on Apr 17, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
on Apr 17, 2024
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
