20 Most Recent
Coby TFTV3229 High Definition TV, 32" Backlight LED Questions & Answers
LCD TV shuts down after about one minute.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi1mvbCzaODAxWGrYkEHcCtDv0QwqsBegQIDRAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DbunKOMKdwcw&usg=AOvVaw1RPdVvQShvGJFeUqr09XWQ&opi=89978449
Coby technical support
It's a throw away. TV out of warranty, buy another tv. sometime they can be fixed by checking the power supply and replacing CAPS other than that consider it a learning experience.
Coby TFTV3229 won't stay on
Although it is not possible to be certain without on-hand inspection, a 5-second or less shutdown usually indicates a SAFETY system is turning the unit off - or that an essential voltage source or control circuit inside the unit is either out of range or has failed. Unless you're an electronics tech or have similar training, this is one of those times when repairs are best left to the pros.
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
Lanzar sd82 input output plug layout
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi8krnznueCAxWxrokEHT0iBfoQFnoECA4QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F577337%2FLanzar-Sd82.html&usg=AOvVaw1NvtQPbnDX49X9-I6oRe-J&opi=89978449
