20 Most Recent Pacific International Pacific Evolution Men's Mountain Bike 26" 18 Speed Questions & Answers
How do i fix the gear lever?
take it t the nearest bike shop
3/17/2015 2:38:20 AM • Pacific... • Answered on Mar 17, 2015
Brand new bike gears won't engage. The gear
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
5/15/2014 11:21:11 PM • Pacific... • Answered on May 15, 2014
Rear hub assembly pacific evolution
Unfortunately, there is only one last ditch effort to free up that freewheel. The following link takes you to a very simplified diagram of how a freewheel works : File Roue libre cliquet svg What's happening in your instance is that the pawl, colored red, is not engaging the outer teeth, possibly due to corrosion, or age. What you can do is use a penetrating oil to get inside the mechanism to try to free it up. In the following link, you will see a freewheel that is most likely similar to yours: Shimano Hyperglide Freewheel You want to add oil to the edge of that inner ring that says "Shimano" (yours may not say that), while spinning the cranks to draw the oil in. Hopefully, after a while, and maybe a lot of oil, the pawls will free up and start catching. Good luck!
3/22/2014 12:18:12 PM • Pacific... • Answered on Mar 22, 2014
I need an owners manual for a pacific evolution bike
Are you sure the derailer or sprocket are not bent? The next thing if not that is the cable itself is it pulling the delairer to release the gear from the gear it is in? one final is the bike just may not go into 6th gear depending on which gear you have the front sprocket in because it would pull the front sprocket to far past the crank space where the pedals are at.
1/16/2013 5:57:53 AM • Pacific... • Answered on Jan 16, 2013
I need an owners manual for the 26" pacific evolution bike.
It is not available.
1/13/2013 12:02:37 AM • Pacific... • Answered on Jan 13, 2013
HOW DO U RAZE THE HANDLE BARS ON THE BIKE
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
A reputable Bicycle Shop would have fit the bike to you before you took it home.
8/22/2011 1:58:12 AM • Pacific... • Answered on Aug 22, 2011
The chain is broken off
The chain goes from the top of the front sprocket to the top of the rear sprockets, between the rear sprocket and the top derailleur wheel and then between the upper and lower derailleur wheels. It then goes forward toward the front sprocket. The text sketch below shows the rear sprocket, chain and derailleur.I hope this helps.
(O
o)
(o
8/16/2011 2:53:56 AM • Pacific... • Answered on Aug 16, 2011
2answers
Why did my tire warp
Tire warped or the wheel? You're too powerful, I guess. Check for uneven spoke tension. Get the tools and learn how to fix it yourself or take it to the shop. DON'T RIDE IT LIKE THAT.
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
7/22/2012 8:07:11 PM • Pacific... • Answered on Jul 22, 2012
2answers
What size is the seat post on the Next px 6.0 bicycle?
The Next PX 6.0 uses a 27.2mm seat post.
1/1/2024 12:50:08 PM • Cycling • Answered on Jan 01, 2024
My gt mach one serial number is SA8Y01976 NEED TO KNOW THE YEAR AND WHERE WAS MADE
serial number is 12900243GT m one. Can anyone tell me the year?
10/24/2023 4:03:47 PM • Cycling • Answered on Oct 24, 2023
3answers
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
10/5/2023 4:17:26 PM • Cycling • Answered on Oct 05, 2023
My bicycle's pedal moves before the wheel. I tried reassembling the chain and the wheel. P.s my bicycle doesn't have a mechanical gear
If your bicycle doesn't have mechanical gears, the issue might be related to the freewheel or cassette, depending on your bike's specific setup.
10/3/2023 10:24:25 AM • Cycling • Answered on Oct 03, 2023
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube. This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM • Cycling • Answered on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM • Cycling • Answered on Apr 05, 2023
I have a 1986 Ford Ranger 2.3L. i cannot locate crank sensor. All i can find in blogs is somewhere by the front pully. well i have it all trorn down and I cannot locate it at all Could it be by bellh
dont think you have one believe 89 started having them ------https://www.justanswer.com/ford/1e5mr-1986-ford-ranger-2-9-liter-spark-fuel-pressure.html
4/2/2023 1:44:37 PM • Cycling • Answered on Apr 02, 2023
Pacific International Pacific Evolution Men's Mountain Bike 26" 18 Speed Logo
12 questions posted
Top Pacific International Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Pacific International Cycling Expert? Answer questions, earn points and help others
View Most Popular
  • Pacific International Cycling
Most Popular Question
rear hub assembly pacific evolution
  • Cycling
