20 Most Recent
GE PGP989DNSS Cooktop Questions & Answers
Why are my gas burners sparking and clicking when
either you have a bad spark modulator or most likely you have a switch that is arched toghether i had same thing happen in a ge cafe where all buners would spark when the unit was plugged in ended up being a switch on right side when i took the switch apart there was a small piece of metal from one side of the switch that had arched to the other side hope this helps
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM •
GE Cooktops
Answered
on Feb 17, 2021
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
11/1/2020 7:28:10 PM •
GE Cooktops
Answered
on Nov 01, 2020
Ge monogram induction cooktop error F
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
1/9/2019 10:31:53 PM •
GE Cooktops
Answered
on Jan 09, 2019
