Question about GE Cooktops
Wiring diagram ge jp350 - GE Cooktops
Posted by Phil OConnor on
NOEL
    Top Expert:
  • GE Master
  • 8,549 Answers
Go to this link and you should find the manual...or the diagram.. Wiring diagram ge jp350 Google Search
Posted on Oct 23, 2017
2 Related Answers
Anonymous
  • 363 Answers
SOURCE: Circuit Braker Jump Off Easily on GE JP350 Cooktop
The ciruit breaker might not be of sufficient rating. Tell us what is the number written on the breaker?
Posted on Oct 27, 2007
Anonymous
  • 4 Answers
SOURCE: GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Posted on Jan 20, 2008
I have a GE 30 in. Profile JP350 Cooktop. The large, front and right control seems stripped and will no longer control the cooktop. Also, the part that it sits on at the cooktop is not protruding up as...
Hi sounds like you have a busted switch assembly, this is very much fixable the part is around $50, but you would need to remove the top of the stove which requires pulling the unit from the counter, this is slightly more involved, but definitely doable i would also change the knob. A more accurate name would be infinite switch.
Sean
Mar 28, 2011 | GE 30 in. Profile JP350 Electric Cooktop
JP350.. Large burner (front right) only the inner circle lights up no matter where the switch is set (large or small). Bill [email protected]
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ewrwer
werwer
Dec 23, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Why is ON light glowing with knobs on off GE PROFILE COOKTOP
That is to tell you that your Infinity Switches are faulty and no good.
So whatever one is lit, change it
Jul 26, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | GE 30 in. Profile JP350 Electric Cooktop
The right front burner will only run on high no matter the setting
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You will need to remove the cook top from the opening to access the switch.You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 06, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Burner not working
try to clean the injector if no gas came out.or try to use matches to have a flame, i think there a problem in ur spark igniter if the gas is going out.tnx
Nov 22, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE Profile JP350 cooktop stopped working
OK, i think the problem took care of itself. definitely got water down in the infinite switch for the lower right burner. let it dry 12 hours and reset the breaker, now works fine. but, i know if i do that again, or if it happens randomly, i will have to replace the switch and seals (available at repairclinic.com)
to do that, you have to remove the cooktop (screwed down by a strap in the back to the back wall of the cabinet) remove the sheetmetal to access the switches and replace. just keep the wiring straight, and ALWAYS replace the seals, they leak over time.
Nov 09, 2008 | GE 30 in. Profile JP350 Electric Cooktop
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Oct 27, 2007 | Cooktops
Cooktops Logo
228 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
