20 Most Recent
Tower Produplicator 5 SATA Burner DVD CD Duplicator Machine Questions & Answers
My produplicator will not display
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including
electrical extensions IDE,SATA
the leads from your
"((motherboard to your hard drive))"
make sure they have a secure connection and are not faulty or just
replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd
3 1/2 inch floppy have secure connections and are not faulty even the electric
extensions or just replace them they could be faulty a computer needs its
connections to continue its cycle and have an end so any faulty leads will end
up with a computer error If your computer came with a motherboard disc the
drivers could be on it or you might have a dirty graphics card remove the
graphics card and clean the socket
hope this
helps
4/15/2019 5:22:59 AM •
Tower...
Answered
on Apr 15, 2019
Hooking up the cables to tower on G6 350?
All questions on Fixya need full 'make model (what it is)' as first 3 words. There are many 'G6 350' including a motorcycle.
If it is the Gateway computer, it is so old to be garbage. Did you find it in a dumpster? It will not function in this modern world.
Gateway G6-350 ; CPU, Pentium II 450 MHz ; RAM, 256 MB PC100 SDRAM ; HDD, 6 GB ; Video, STB Velocity 128ZX ; Sound, Creative ES1373 ... And it only runs Windows 98!
All the plugs on the back are marked.
https://www.google.com/search?q=Gateway+g6+350+connect+cables
If i purchase a new i7 core processor and mother board can I use an old pc tower to intall it into, if not what do i need to do to make the new hardware work
Certainly, if the motherboard fits the space you could mount it just about anywhere you fancy.
In the early days of personal computing very few companies produced them and not only were the prices eye-watering and beyond the means of the majority, the specifications were more reliable than performance - the early PC didn't even have a hard disc drive and the floppies were 5"...
This led to a host of suppliers springing up to satisfy those wishing to save money by building their own and add performance to the finished items or to boost the performance of cheaply bought ex-business machines. These suppliers soon started producing machines for resale...
In those days the desktop was king and it all started with an empty case the customer would fill with the parts he could afford - the tower computer came later.
You need to read the motherboard manual before you start and ask for specialist help to instal the processor and fan - the other stuff; the memory, the hard drive and other ancillary stuff such as the drives and leads should be the highest specification if you are going to obtain the benefit of your high specification motherboard and processor...
Ensure the power supply has the correct connections for the motherboard and can supply enough power with a comfortable safety margin. It would be wise to fit at least one extra fan - I have been inside a couple of high spec quality machines and they had fans that could have kept a small car engine cool, though another was completely fanless but that is to be avoided due to the huge processor heatsink and the case being designed around it to produce a high velocity convection air current...
F1 Lloyd tower AC
It might depend on the brand and model of your air conditioner, but on several varieties, E4 means it is iced up. Switch it fan only for a while (ten or twenty minutes) and reset the air conditioner by turning it off for a few minutes. When you turn it back on, the error code may be fixed.
How can i insert a CD in the tower to add a program
The CD Drive will have a small button you can press, to eject the CD tray. Then you can place the CD in the tray. Then press the same button to close the CD tray.
I've shown one example in the picture attached. The button is shown marked by the yellow circle.
Why was my 'Win7u Login Password Forgotten' question removed?
no
the reason could be that you never got an answer because of the way you asked the question, not enough details provided or simply that there was no one interested in answering
In the time I have taken to answer this , another 25 questions have been added to the list so if it is not seen in 30 minutes , it is too far past to even chase up
