20 Most Recent Coleman 5640B807 Compact Refrigerator Questions & Answers
0answers
0answers
Igloo Koolmate model 1301405, I need power cord
Call their customer service. The number can be found on their website. They have it and it can be sent out, it just isn't listed on their website. I ordered mine a few months ago. It was a little more than I wanted to pay, but a small price for a working unit on a road trip!
11/3/2011 3:00:54 PM • Coleman 5640B807... • Answered on Nov 03, 2011
A small amount of cold
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/19/2010 1:57:41 AM • Coleman 5640B807... • Answered on Aug 19, 2010
Fan motor for my coleman icebox model564
Check with your local computer or electronics hobby store.
Recomend you remove the original fan and take it with you to the store so they can match it to one they may have in stock.
9/21/2009 3:58:01 AM • Coleman 5640B807... • Answered on Sep 21, 2009
Conecting to 120 volts AC
If you want to get more precise, figure out everything in terms of power (watts).
Basic electrical rule 1, 2 and 3:
voltage x current = power
or re-arranged:
current = power divided by voltage
or re-arranged:
voltage = power divided by current
For example, 12V X 2 amps = 24 watts.
or another example, 400 watts divided by 120 Volts = 3.33 amps
A 55W headlight that uses 12V would draw 55 /12 = 4.6 amps @ 12V
A 55 watt light bulb in a lamp at home would draw 55 / 120 = 0.46 amps @ 120V
As the previous post mentioned, inverters are not perfect when convertering 12V into 120V. If the converter consumes 1000W from the 12V battery, then a 90% effecient converter would generate 900W of 120V AC power best case. The other 100W is lost primarily as heat.
The other thing that gets tricky is that these ratings and the formula above are used for resistive loads, like light bulbs or hair dryers. Anything with a motor or transformer is considered an inductive load and can get much more tricky to calculate.
Consequently you need to give your self a safety margin when figuring out how big an inverter you need.
How does work in a practical sense?
Lets say you want an inverter for TV, DVD and Sat. Receiver. Look at the back of TV or in the manual. It should say how many watts it consumes. Lets say it is 400W. The DVD might be 100W and the Sat. receiver 50W - just as an example.
400 + 100 + 50 = 550 Watts. (just as an example)
You might think, well no problem, I'll use a 600 Watt inverter and have 50 watts left over. Depending on your inverter, that 600W might really be 600 x 90% effecient = 540 Watts of AC, less a 20% margin of error for the inductive transformers in the electronic of the TV, DVD and Sat. receiver 540 - 20% = 432 Watts.
Now you can see your 600 Watt inverter isn't big enough to do the job.
If we really need 550 watts of AC, add 10% to make up the effiency loss, then add a safety margin for inductive loads.
550 + 10% = 605 + 20% = 726 Watts.
Sounds more like an 800W inverter fits the job.
What does that mean in terms of wiring the 12V batteries to the inverter?
from the formula above:
In our example, we have an 800W inverter that runs on 12V
The current would thererfore be:
current = 800 watts divided by 12V
current = 66 amps.
That is important info because you can not use light gauge wire to carry 66 amps worth of 12V to the inverter nor could you use a 20A fuse to protect your inverter.
Now that's a lot of science for a guy who just wants to run a toaster on an inverter right?
800W / 120V = 6.66 amps
Using garryp's ratio 11:1, 6.66 x 11 = 73 amps.
That is a good ratio with a good safety margin.
This is all just MHO and should not taken as solid technical advise. In other words, don't blame me if you blow yourself up.
11/26/2008 2:02:43 AM • Coleman 5640B807... • Answered on Nov 26, 2008
0answers
Fan motor
Be the first to answer 10/6/2008 6:58:54 PM • Coleman 5640B807... • Posted on Oct 06, 2008Be the first to answer
0answers
2answers
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM • Home • Answered Yesterday
2answers
My digital thermometer not showing LO singnal
Lo batteries or too far away or interference will cause this.
4/21/2024 11:46:07 AM • Home • Answered on Apr 21, 2024
Seth Thomas wall clock, Model 2645 Manager 14Q. Running fast. How do I adjust it?
You can adjust it by the length of the pendulum. This lik will walk you through the process: http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
4/20/2024 12:02:05 AM • Home • Answered on Apr 20, 2024
2answers
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM • Home • Answered on Apr 16, 2024
3answers
Atomic Wallet Support Number
However, Atomic wallet is available in desktop and mobile versions which provides convenience. And it is a decentralized wallet where you will get private key for every coin you store in it. It is an open source wallet which means no one can infuse any malicious code into it. https://steemit.com/atomic/@abhijeetcg/atomic-wallet-comparison-with-other-existing-crypto-wallets
4/12/2024 11:27:48 AM • Home • Answered on Apr 12, 2024
3answers
What are the different types of fire extinguishers?
there are 3 types:watercarbon dioxidedry chemicalto learn more about them go here: http://www.ehs.okstate.edu/modules/exting/Types.htm
4/10/2024 10:24:39 AM • Home • Answered on Apr 10, 2024
Coleman 5640B807 Compact Refrigerator Logo
13 questions posted
Top Coleman Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Home Expert? Answer questions, earn points and help others
View Most Popular
Coleman Home
  • Coleman Home
Most Popular Question
igloo koolmate model 1301405 need power
  • Home
