20 Most Recent La Crosse Technology Radio Controlled Post Office Regulator Clock Questions & Answers
How can I get my clock to chime the right time? It is always one hour too much.
  • First see if changing the time with the battery out changes the time without changing the cycle on the chime - I could just imagine somebody adjusting the clock for daylight savings and the clock doesn't change it's chime cycle correctly with the battery a certain way - in or out - maybe it's the opposite and you have to take the battery out and somebody didn't now you have to leave it in.
  • Check the internet for the original manual if you know the model.
  • Look for clues to setting the chime on the back? is there a separate knob - are the batteries both good?
Still not working after playing with it? Here is the mechanical way to fix it: Sounds great, but it still is chiming the wrong time after playing with it? This will fix it:
  • Set the clock for exactly at the chime - I suggest 3 o'clock chime - the hands will be wrong (2 or 4 or whatever)
  • Remove the battery(s) - I do custom imprinted clock faces and it seems to me that 3 o'clock is the easy place for me to put the hands back.
  • Take the clock apart - usually it is tiny screws on the back, or you will see 3 or 4 v shaped wires. push the v wire out of one side - they are springs that some clocks use to hold the rim instead of the screws - they are easier than they look - just pull one side and remove.
  • Gently pull up each hand off the shaft. I hope you have fingernails.
  • Replace the hands back at exactly the time that they are supposed to be (3 o'clock in my example) - you start with the hour hand and gently push on the spindle make it look level and all the way on - then the minute hand at 12 also level
    • Remember to play with the time first so you'll be happy that you put the hands exactly where the chime should start.
    • Remember to make that time be exactly on the hour with the small hand and exactly on the 12 with the big hand so the hands line up correctly.
11/9/2015 10:51:19 PM • La Crosse... • Answered on Nov 09, 2015
2answers
I have a 60 inch adjustable screw Jack basketball hoop portable and I lowered it down too far how do I raise it back up it won't raise up
Lay it on the ground, gently pull the hoop and turn the screw.
4/18/2024 10:44:09 AM • Sport & Outdoor... • Answered on Apr 18, 2024
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ? I am located in BC Canada Reg 250-379-2971 [email protected] if you can contact me ?
3/23/2024 12:45:15 AM • Sport & Outdoor... • Answered on Mar 23, 2024
3answers
How do i pick out a tennis racket?
This website has a fabulous guide to picking out a tennis racket!http://www.wilson.com/en-us/tennis/rackets/racket-selector/
3/11/2024 10:21:05 AM • Sport & Outdoor... • Answered on Mar 11, 2024
Queria o manual em pdf da barraca ozark trail hk-5100, onde posso conseguir?
English only on Fixya please.
Ozark Trail Tent User Manuals Download
ManualsLib https://www.manualslib.com > ... > Ozark Trail Manuals Download 66 Ozark Trail Tent PDF manuals. User manuals, Ozark Trail Tent Operating guides and Service manuals. https://www.google.com/search?q=Ozark+Trail+HK-5100+tent+instructions ..
3/5/2024 10:45:39 PM • Sport & Outdoor... • Answered on Mar 05, 2024
Where is the femur located
Good day are you referring to the human body, if so the femur is located in the thigh.
2/20/2024 5:30:32 PM • Sport & Outdoor... • Answered on Feb 20, 2024
How can I maintain my pool table at top condition?
In order to maintain the condition of your table and prolong its lifetime you should avoid eating above the table, putting drinks of ash trends on the sides of the table, and generally try not to harm the cloth with the cue. In addition you can clean and vacuum the table from the outside once a month, this Is what I'm doing to my table.
2/7/2024 10:05:02 AM • Sport & Outdoor... • Answered on Feb 07, 2024
What is the price range of a quality foosball table?
Good quality and long-lasting table start at about $600. In this case, like in many others, the more you pay, the better quality you will get. Make sure that you're buying a known brand and compare prices first, before you buy. It is also recommended to read some reviews about a table or tables that you like.
2/6/2024 9:20:46 AM • Sport & Outdoor... • Answered on Feb 06, 2024
2answers
How do I order a replacement part for a sportcraft foosball table? I cannot find a contact number for the company
You may not find it, however an epoxy may be suitable to repair the broken pieces. Or you may be able to screw a support plate to the side piece, inside where it will not show.
1/30/2024 6:22:22 AM • Sport & Outdoor... • Answered on Jan 30, 2024
Does anyone have the instruction manual for Spinifex Huon #90028976 tent please?
Help in the link, but nothing specific to yours. They all work to a theme and there is full instructions for Spiniflex Albany and contains their contact details.
spinifex - Anaconda
anacondastores.com https://www.anacondastores.com > medias > Spi... PDF Read all instructions before set up. Select a level site clear of rocks, branches, and other hard or sharp objects, to install your tent. https://www.google.com/search?q=spinifex+huon+tent+instructions ..
1/26/2024 7:41:48 PM • Sport & Outdoor... • Answered on Jan 26, 2024
I am after the owners manual for Spinifex Huon tent model #90028976
DID YOU MANAGE TO GET THE MANUAL FOR THE SPINIFEX HUON TENT ALISON ?
1/26/2024 2:18:46 PM • Sport & Outdoor... • Answered on Jan 26, 2024
2answers
How to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
1/22/2024 2:26:23 PM • Sport & Outdoor... • Answered on Jan 22, 2024
Need a manual for an
Here ya go...free pdf download from the eagle website:http://www.eaglenav.com/upload/Eagle/Documents/Manuals/Fish%20ID%20II.pdf
1/3/2024 2:07:55 PM • Sport & Outdoor... • Answered on Jan 03, 2024
2answers
I'm in my 50's, can I start playing table tennis?
Definitely! You should know that Table tennis is asport for all ages, and it is never too late to get started. You should know that in the year 2008, Olympic table tennis canbe called the Veteran Year as 38 year old Gao Jun and34 year old **** Chendirectly qualified for the 2008 Beijing Olympic Games on the women's side. Andon the men's side, 45 year old David Zhuangwon the right to attend the Olympic Games as the USA' sole male representative.
1/2/2024 11:20:12 AM • Sport & Outdoor... • Answered on Jan 02, 2024
Need poles for avid outdoor tent with screen house. Originally bought from big w
try outdoor or hiking retailers for spare poles take the name of the manufacturer and the brand name and model to help identify the poles
1/1/2024 7:48:01 AM • Sport & Outdoor... • Answered on Jan 01, 2024
Manual for metal detector and treasure tracker DX5000
I have my father in laws treasure tracker DX 5000 I missed placed on manual?
12/31/2023 3:22:28 PM • Sport & Outdoor... • Answered on Dec 31, 2023
6answers
I have been playing tennis for a few years now in
If you are undergoing coaching, then you already are following a tennis specific program. But the intensity of your training depends on the level of tennis you play. To further improve your fitness, you could try to go to some tennis coaching centre or clinic of repute that provides a tennis specific training regimen. They would have a program that would help improve your technique, breathing, endurance, etc. Depending on their quality, they might have trainers who could work with you individually to help identify your strengths and weaknesses. As far as improving your court coverage is concerned, a good training centre apart from the normal training might provide separate athlete agility training programs that can be custom suited to your needs. There could be several such centers in Mississauga and Toronto.
12/29/2023 9:35:15 PM • Sport & Outdoor... • Answered on Dec 29, 2023
La Crosse Technology Radio Controlled Post Office Regulator Clock Logo
1 questions posted
Top La Crosse Technology Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a La Crosse Technology Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Technology Sport & Outdoor - Others
Most Popular Question
get clock chime right time always one
  • Sport & Outdoor - Others
