Contributor
- Posted on Nov 09, 2015
Re: How can I get my clock to chime the right time? It...
- First see if changing the time with the battery out changes the time without changing the cycle on the chime - I could just imagine somebody adjusting the clock for daylight savings and the clock doesn't change it's chime cycle correctly with the battery a certain way - in or out - maybe it's the opposite and you have to take the battery out and somebody didn't now you have to leave it in.
- Check the internet for the original manual if you know the model.
- Look for clues to setting the chime on the back? is there a separate knob - are the batteries both good?
Still not working after playing with it? Here is the mechanical way to fix it:
Sounds great, but it still is chiming the wrong time after playing with it? This will fix it:
- Set the clock for exactly at the chime - I suggest 3 o'clock chime - the hands will be wrong (2 or 4 or whatever)
- Remove the battery(s) - I do custom imprinted clock faces and it seems to me that 3 o'clock is the easy place for me to put the hands back.
- Take the clock apart - usually it is tiny screws on the back, or you will see 3 or 4 v shaped wires. push the v wire out of one side - they are springs that some clocks use to hold the rim instead of the screws - they are easier than they look - just pull one side and remove.
- Gently pull up each hand off the shaft. I hope you have fingernails.
- Replace the hands back at exactly the time that they are supposed to be (3 o'clock in my example) - you start with the hour hand and gently push on the spindle make it look level and all the way on - then the minute hand at 12 also level
- Remember to play with the time first so you'll be happy that you put the hands exactly where the chime should start.
- Remember to make that time be exactly on the hour with the small hand and exactly on the 12 with the big hand so the hands line up correctly.
