20 Most Recent
Haier HL42R 42 in. LCD TV Questions & Answers
My haier 42
Most likely the set will need to be serviced. You either have a issue with the power supply or main board. A proper diagnoses will need to be done to be sure. You can try unplugging the TV for a while and trying it again. I doubt it works but it's worth a try
No signal apears on screan
check that all your cables on the back are connected properly and same on your antenna or cable box or satellite.
How do I attach my dvd to the 42 inch tv to watch
An HDMI cable is best however a set of Component cables will also work. The Component (RGB) will also carry a high def image. You will need five cables in all. The Red, Blue, Green for the video and two additional RCA cables for audio (red and white). Color match the inputs to both the DVD and the TV. Select "Video" source from the Input menu of the TV. Confirm this worked.
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
