Question about Haier HL Televison & Video
How do i hook surround sound to my Haier TV L26B1120a
All ready have a stereo hooked to it & that also has a dvd player made in to it but i also want to have the sound of the tv come out the surround sound
Elaine Armstrong
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Are you using a cable or satellite box? If so you can connect the audio out jacks to the Surround Sound instead of the TV.
Posted on Jun 03, 2018
5 Related Answers
Anonymous
SOURCE: hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Posted on Oct 06, 2008
Anonymous
  • 44 Answers
SOURCE: Hooking up surround sound to TV
You have to get an optical audio cord.
The optical output on the vizio is right next to the ac cord. Make sure that your audio amp has the same input conection.
Lou Margo
Allied Electronics
[email protected]
Posted on Dec 16, 2008
Anonymous
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
Anonymous
  • 1077 Answers
SOURCE: I hooked my dvd player up to my tv. There is no sound
You have a great night too.
Happy DVD movies. :)
Posted on May 25, 2009
Anonymous
SOURCE: surround sound dvd player/tv channels are fuzzy
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Posted on Jul 12, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Cant get sound surround out of tv
Have you tried looking at the sound set up menu on the TV? Some sets will only output sound via certain sockets which have to be switched on. Others will only output sound via internal speakers till they are switched off etc.
Tried hooking up the DVD player and get no sound & the color is really bad. I have the red, blue & green hook up am I missing something?
You have component cables from your description. Make sure that each one is in the right slot on both the DVD output and the TV input. As for the audio, the component cables do not carry audio, so you need to hook up audio out from the DVD player to audio in on the TV. Usually red and white RCA jacks for audio plugged into their respective color coordinated ports. Good luck and I hope this helps.
Surround sound dvd player/tv channels are fuzzy
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Surround sound
How do I hook-up my surround sound system with powered sub woofer to my Sony stereo receiver and sony dvd player?
2answers
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Televison & Video Logo
Top Haier Televison & Video Experts
Kolbrun...
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
