Hi
You will have to open the back of the television to repair the television, and care must be taken by unplugging the power plug of the television.
A common problem for these is bad capacitors in the power supply, Remove the back from your Television and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this help in solving the problem and do take care because it contain high voltages
