I have a Goodman AC unit that isn't cooling well in the afternoon heat and can't locate the BTUs or tonage anywhere on it. Model CKL 30-10, Serial# 0202462537, AC volts 208/230, Phase 1, Hertz 60, voltage range 197-253, min. circuit amps 18.9, fuse amps 30, compressor: RLA 14.1, LRA 73, fan motor: FLA 1.3, HP 1/6, factory charge R22 70, pressure test low 150 high 300, MEA No. 348-96-E, Part# P14932096. This is all of the info. on the metal tag on the unit. Can you tell me where to find tons? Thinking house may need bigger unit. Thanks so much!
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
That is a 2 ton system. Look at the model number and the 24 is the giveaway. A ton is = to 12,000 btu's. 24 = 24,000 btu's whick is 2 tons of cooling.
Hope this help's!
Audie
here is a link to a pt chart click at top right all you need. just google how to take super heat or sub cooling if you dont know how. super heat should be @ 7-12 and ur fine. if you are over 32 deg f or 55 psig u should also be fine
Many HVAC people talk in tonnage. One ton is equal to 12,000 Btus. Therefore your model specifies your cooling tonnage at 3 and 1\2 tons. Your heating would be determined by how many if any supllimentary heat strips are added. If you live in Anahiem or Miami that's not really important. But if you live anywhere that gets down into the 40's at night you'll want strips. Cooling wise depending on where you live and what your insulation is like, I'd say your unit is good for 1100-1300 Sq feet of living space.
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
