Samsung Galaxy S GTI9000 Smartphone Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant get into my market because of my pass word is incorrect how do i reset pass word?
Anonymous
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Aug 16, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
55
Questions
0
Helped
60316
Points
130
Well if it is your google password that you can't remember (you will have to reset it with google services -> forget password can be found under login prompt on gmail homepage.If you know your google password, but it is entered incorrectly you can use Settings -> Accounts and sync and on that section just find your associated google account and press and edit it. You can then remove your account and add correct one.
Unlock code parent
for ps3 the default is 0000 if you go into settings and restore the ps3 to default it will reset it to that
if its PS2 go the link below:
http://www.wikihow.com/Reset-the-Password-on-Your-PS2
for the wii go here:
http://en-americas-support.nintendo.com/app/answers/detail/a_id/2982/~/forgot-parental-controls-pin
and for xbox do this:
If you've forgotten your pass code, you can reset it by answering the pass code question you set up parental controls. Here's how:
1. On your console, go to Settings, and then select Family.
2. Select a content control setting to change.
3. When you're prompted, enter any pass code (even though it's incorrect).
4. When you're notified that your pass code is incorrect, select Reset Pass Code.
5. When your pass code question appears, use your controller or chat pad to enter the answer, then select Done.
If you can't remember the answer to your pass code question, you'll have to contact Xbox Support for further help.
...............hope that helps
I forgot my family settings pass code and reset code for the xbox 360
Reset a Forgotten Pass Code To reset your Family Settings pass code after you've forgotten it:
  1. From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
  2. Enter an incorrect pass code.
  3. You will be told that your pass code is incorrect. Select Reset pass code.
  4. You will then be shown your pass-code question and asked to answer it.
    Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
I bought my xbox 360 from a buddy a few years back and my brother as of recent has been an *** and i want to set a passcode of the 360 itself so he cant use the xbox live without the code. and there...
Hope that helps, best of luck.
I had a sim in it and took it out so I could put in my old sim to copy the contacts on to my defy but when it turned on it said to unlock enter gmail account and password, I did this a few times only to...
mine did same,i guess it just recgocnise first login details,you can resotore setting and see you cant start again,can your phone work without sd card,mine cannot and also i cannot download apps from android market,tried but it says downloading qued dont know what to do.
A couple of years ago i made my xbox live account and accidentally set the family settings to high now that im using my xbox agian i cant really do anything on live since i dont remember my password or...
spacer.gifReset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
I put on a family timer on my sons xbox and i can remember the pass code
To reset your pass code, repeat this procedure at any time.
We have forget our familysetting passcode give us a code immerdiatly
Here is what you can do
My xbox 360's parental controls won't disable and I can't download stuff even though it says...I tried the override code but it doesn't work...any suggestions??
1helpful
Can u give all the combinations for family setting problem.
Reset a Forgotten Pass CodeTo reset your pass code after you've forgotten it:
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
