Lisa, unfortunately, Haier for whatever reason does not list what error codes mean, in their Owners Manual. You will have to contact Haier Customer Support 1-877-337-3639 for that.
In the meantime, turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then, plug the unit back in and turn the ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. If they did, you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
Remove the front cover and check out the circuit board. Due to Haire's poor design it is probably soaking wet. Dry it out and the code should clear and you should be able to power the unit back up. The wiring harness is actually long enough to let the unit operate with the front cover removed while the unit is running and allow the board to be protected from getting wet in the future.
