Fan is running but no dehumidification - no water . Compressor is very hot to the touch
Make sure the coils are clean both evaporator and condenser,then if there is a capacitor in the motor circuitry,check this,finally if the coils frost,then clear up and frost and clear up time and again,this is a sign of low refrigerant R134a,and this also will make the compressor run hot
Testimonial: "Now I need to frigure out where and how to install the fix"
you need to purchase what they call a saddle-tap and install it on the low pressure line side of the compressor,then get a 1 lb can of the right number (i.e. r134a) refrigerant thats marked on the unit label,then get the fill hose for the can and open it and add very slowly and with the can upright so you only add vapor and feel the compressor while its running and it will cool down as you add ,but be careful not to add too much as most of these only take about 2 ounces at the most,but consult the mfgrs tag on the unit for its capacity
probably low on refrigerant. Unit is only 1 1/2 years old. How do you add refrigerant to it?
I HAVE A NEW DEHUMIDIFIER IT BLOWS WARM AIR OUT
