Cars & Trucks Logo
Posted on Aug 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On returning yesterday from a 3 week holiday our 6 month old honda wont start . The recovery guy said the battery was flat and used jump leads to get it started . We took it for a drive , and find today it wont start again , and are waiting for the recovery man again . The recovery guy said it is a problem with modern cars , seems crazy is that correct ? Would welcome some advise Thanks
Mike Butler
Level 3:
  • Honda Master 6,674 Answers
  • Posted on Aug 30, 2008
Mike Butler
Honda Master
Level 3:
Answers
6674
Questions
10
Helped
2895065
Points
19845
Disconnect your battery (+ ) terminal for a minute or so, then reconnect. I've had where my vehicle came back from Florida, the night before, to the nice cold winter in Ontario Canada, and I had to disconnect battery to basically re-program all the sensors etc, to recognize difference in temperatures. After I did that, it started up fine, no more problems. I don't suspect your vehicle was exposed to any big difference in outside temperatures, but it costs nothing to try this, and I've seen stranger things happen.
2answers
I have 2002 Escape xlt that died in heat. I have 10k miles on 3yr old AAA battery. How do I tell if battery or alternator?
start engine ? (jump leads) then with engine running disconnect battery terminal anyone ,then if engine stops its the altenator if engine keeps going then its the battery
tip
Jump-start Jaguar X-type? it's more complicated than you think.
Jump Start of Vehicle Battery
IF THE BATTERY YOU ARE USING TO JUMP-START THE VEHICLE HAS RECENTLY BEEN CHARGED IT MAY STILL BE GASSING, COVER THE VENT PLUGS OR COVERS WITH A DAMP CLOTH TO REDUCE THE RISK OF EXPLOSION SHOULD ARCING OCCUR WHEN CONNECTING THE JUMP LEADS.
Turn off all electrical ancillary circuits such as radio, lights, indicators etc. If the reason for a flat battery is unknown the condition may be as a result of an electrical short circuit, so care must be taken during the Jump-start process and subsequent to connection to ascertain if this is the case. A short circuit or un-isolated ancillary load can cause arcing when the jump leads are connected, a small 'crackle' is normal but any spark or flash is an indication of a problem that should be rectified before attempting to Jump-Start the vehicle.
Jaguar do not recommended that the vehicle is jump started, and If at all possible it is preferable to replace the flat battery with a suitable fully charged unit rather than jump-start the car. However if it is done it should be carried out by suitably qualified personel. Garage services and services like AA and RAC homestart should be used whenever possible.
Obviously there are occasions when carrying out this proceedure yourself is the only practical way proceed.
If there is no option but to jump-start the discharged battery should be removed and recharged immediately after jump starting to avoid permanent damage.
High quality, heavy duty Jump leads must be used as the current consumption during starting is very high, and a voltage loss will be
exhibited though the jump leads, increasing current requirement.
Make sure that the Jump Start battery is of the same voltage as the vehicle, and suitable to provide the required starting current.
MAKE SURE THAT THE ENDS OF THE JUMP LEADS DO NOT TOUCH EACH OTHER OR GROUND AGAINST THE VEHICLE BODY AT ANY TIME WHILE THE LEADS ARE ATTACHED TO THE BATTERY. ARCING AND VERY RAPID DISCHARGE CAN CAUSE THE BATTERY TO EXPLODE.
Connect the jump leads in the following sequence.
Connect Positive Jump Lead to Jump Start battery positive terminal.
Connect Positive Jump Lead to Vehicle battery positive terminal.
Connect Negative Jump Lead to Jump Start battery negative terminal.
Connect Negative Jump Lead to a suitable vehicle ground point at least, 300 mm (12 in) from the battery terminal e.g. engine lifting bracket, do not do not connect directly to the vehicle battery terminal.
Start the vehicle and rev to 2000 rpm, then allow tickover for 5-10 minutes.
Do not attempt continued repeated starting of the vehicle, this will cause heat build up at the terminals and though the jump leads degrading the leads performance and adding to voltage loss.
Allow 3-4 minutes recovery time for the leads and Jump Start battery between attempts to start.
Before disconnecting the jump leads, switch on the heated rear screen, to reduce the alternator voltage peak when the leads are removed, as this can damage electronic equipment.
Disconnect the jump leads in the reverse order to the connecting sequence taking great care not to short the ends of the leads.
Do not rely on the alternator to restore a discharged battery.
Ensure that the battery is recharged or replaced with a fully recharged unit
as soon as possible.
Following Jump-starting of a compleately discharged battery, you may need to carry out a Green ECM drive Cycle, this will allow the powertrain control module to 're-learn' idle values, and most likely need to re-enter your radio code, details of these can be found at. http://www.bluejag.co.uk
2answers
Gave a guy a jump yesterday my mom & the guy went
Hi LINSEY,CHECK YOUR WIRING AT YOUR POSITIVE BATTERY,COULD OF BURNT IT UP,THE FUSIBLE LINK.
Kangoo van 17dci laying for 8 weeks and now wont start
when you say won go do you mean that there is no power at all,( flat battery,) there is power only lights in the dash? First of all check whether you do have powerful Battery for a crank start. If not then ask for a help from a qualified electrician to jump start it by means of a strong battery and leads. 8 weeks it is a long time for a battery to drop power down possible completely dead if the battery is old.
Car has been sitting 5 months without being started
the battery may be shorted out. do you have a meter to check a batteries condition? if not take the battery into the parts store and they can tell you if it has a dead short in it which means the plates inside the battery have sulphated together and wont allow current to pass through them. lead acid batteries are real bad about this if they go completly dead even if they are newer batteries.
Lights staying on
You need a new ignition switch.
5helpful
2answers
Trail blazer wont start
hi its rob sounds like ur battery needs changed when a battery is left to go flat the cells start to buckle each cell is two volts if u loose just one of these the battery will not hold its chardge.sometimes u can get intermited chardge were it will be ok one minute and the i will just dye the next
1helpful
Clicking starter=car not starting
the battery is located under the rear seat, check battery connections. if connections are tight replace starter.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
