Philips 52PFL7403D 52 in. LCD HDTV Logo
Anonymous Posted on Jul 19, 2011
Screen is black after the initial white screen that displays "Philips" Sound there but black screen with no picture Menu does not show either Nothing but black
Anonymous
Level 2:
Scholar:
  • Expert 81 Answers
  • Posted on Jul 19, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
81
Questions
0
Helped
22141
Points
249
I believe a firmware update can fix this issue. However to be sure I would need your entire model number, including the numbers after the slash. You can put that entire model number into Philips support website, http://www.usa.philips.com/#/headernav/consumer/
Once you get to your TV's support page, you can look on the right hand side and find the firmware information. First I suggest you read the Read Me file to familiarize yourself with the update process and what issues it fixes. Then you can download the firmware to your computer so you can upload it to a USB drive to perform the update.
Hope that helps!
  • lgbass1332 Aug 23, 2011
    It did not solve my problem. Nothing happened. I do not even know if the update occurred on the tv, because nothing changed. The tv never turned off, nothing flickered. I did not hear anything, so all I can say is that it did not fix my problem. Note: unable to get to the menu to check it manually, bc the screen is still black
tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
tip
SERVICE MODE AND ERROR CODES CHECK
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
LN32B360 no picture
does the display totally black or white screen then how about the sound still working.
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
