SOURCE: trying to program my Radio Shack 15-2147 remote to my emerson tv
I need the Sony TV code for 3-in-one remote
SOURCE: code needed
Here's the link to the Radio Shack product document support. It has all the codes and how to info.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502200_PM_EN.pdf
SOURCE: need code for AKAI LCT2016 for Radio Shack 3-1 universal remote
0105 0002 0077 1137 1138 0254 1105 1113 1139
SOURCE: my radio shack 3 in 1 remote doesn't work with my zenth tv/vcr
Three-In-One Easy Remote
(150-1916) Troubleshooting Faxback Doc. # 16723
SCANNING THE CODES
If the 3-in-1 does not control your remote controlled devices when you
first set it up, you probably haven't entered the correct 3-digit codes for
your devices.
You can try all the codes for the brand of your device, but because many
manufacturers make products using several different brand names, you might
want to search the 3-in-1's entire library of codes as follows:
1. Manually turn on the device you are trying to set up.
2. Aim the 3-in-1 at the device.
3. Before you press P, you need to press the device key (TV, VCR OR CBL)
for the device you want to control.
4. Press down and hold P until the red indicator blinks twice.
5. While holding down P, repeatedly press PWR then the desired device
key (TV, VCR, or CBL) until the device responds.
Each time you press PWR then the device key, the 3-in-1 advances to
the next manufacturer's code in its list.
6. When the device responds, release P to lock in the manufacturer's
code.
If necessary, repeat these steps for each device key.
CHECKING THE DEVICE CODE
To determine which 3-digit code the 3-in-1 is set to for a particular
device, press and hold P until the red indicator blinks twice. While
continuing to hold down P, press the device key (TV, VCR, or CBL) then
press 1. The 3-in-1 "blinks out" the number of the first digit. For
example, if the first digit is 2, the red indicator blinks twice. While
continuing to hold down P, press 2 for the second digit, then press 3
for the third digit.
NOTES: If the device code has a 0 in it, the red indicator does not blink
for that number of the 3-digit code.
If the 3-in-1 stops working after you successfully test the control
of each device, or if you are unable to get the 3-in-1 to work at
all, check the following:
Be sure you press the device key for the device you want to
control.
Check and replace the batteries, if necessary.
Confirm that your remote controlled devices are working
properly using manual controls or their original remotes.
If some buttons do not work for your device, you might be able
to scan to a better device code.
If you are still unable to determine the problem, call the nationwide
Universal Remote Control Hot-line at 1-800-955-2599.
SOURCE: Need the code for a LG brand tv on a radio shack 3 in one universal remote control....
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
None of the codes listed under Sylvania, Funai or other related brands has worked.
I just bought a Philips 3576 and connected it to my 21-year old Magnavox projection TV (model # RH8530 AK 09). I can't get them to communicate. My original TV remote was lost and I got a Radio Shack 3-in-one remote, model #15-2143. I tried all the methods in the remote manual to find a code for the 3576, but none will work. I need to get to the SETUP menu on the 3576 via the TV remote. Is there some way to make it work? If yes, please explain in the simplest terms cuz I'm not technilogically savvy. If no, can you tell me how to accomplish this?
I need to know what buttons to push to manually program my remote to my magnavox tv
