20 Most Recent Sylvania 6313CB 13 in. TV/VCR Combo Questions & Answers
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Sylvania 6313CB... | Answered on Mar 19, 2013
they will not work for this set, only the original remote will work
Sylvania 6313CB... | Answered on Mar 18, 2012
hi,
Try the following codes
if you have four digit universal remote then codes are
0054, 0030, 0020, 0096
If you are using three digit universal remote then codes are
054,030,020,096
ok
Sylvania 6313CB... | Answered on Jul 07, 2011
Hello
The tape film has been coiled with its VCR mechanism parts and prevents the mechanism to shut OFF properly. This situation will be sensed by the main system control IC of your TV and it will shut the whole system OFF. That is happening now. To rectfy this, you have to open the unit and take out all the coiled tape film from the mechanism. In fact, the set should be deassembled as a whole. If you hav enough tools to do it, you can do it by yoursef. There is no components to be replaced. Only remove this coilde film from the mechanism OK.
Sylvania 6313CB... | Answered on Jun 26, 2011
Hello
Universal remote code for Sylvania TV/VCR Combo is:
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sylvania 6313CB... | Answered on May 31, 2011
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive House Voltage were detected.
Sylvania 6313CB... | Answered on Jun 01, 2010
Check the belt of the vcr maybe are on bad conditions and don't make it's function correctly
Sylvania 6313CB... | Answered on Apr 12, 2010
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
Sylvania 6313CB... | Answered on Mar 28, 2009
if you do not have cable, fios or directv you will need the converter box
Sylvania 6313CB... | Answered on Mar 14, 2009
The load motor usually actuated gears that are oriented vertically and on one side of the tape intake cage. If the unit is apart, it should be obvious where they are.
Sylvania 6313CB... | Answered on Mar 05, 2009
Many times, Cam Gear in VCR gets Stuck due to its age (Loose Belt most time).
Or,
The Cassette Housing is off Track (Usually Bent, or Toys inside!!!)
Solution, if you are not all thumbs,
1) UN-PLUG first!!
2) Get Alcohol Pad Ready.
3) Open Back Cover,
4) Clean the Belt on Worm gear (Usually Side of the mechanism towrds back).
5) while at it, Make sure to Dust with Air Aerosol (like ones that you use for computer)
50% of time this will Fix the Problem!!
Sylvania 6313CB... | Answered on Jan 29, 2009
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Sylvania 6313CB... | Answered on Jan 16, 2009
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Sylvania 6313CB... | Answered on Jan 08, 2008
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sylvania... | Answered on Oct 13, 2020
It's the fuse in the electric engine. You can bypass this fuse by cutting it off and then you just connect the two ends together, wrap with electrical tape. It'll work, that's what I did to mine. Works great again
Sylvania... | Answered on Sep 06, 2020
A lot of people are confused about turning the TV 'off'. If there is a light showing when the TV is 'off' it is merely on 'stand-by' and not truly off. Off means being physically turned off by either the switch on the set or the mains. using the remote to turn 'off' the TV will not turn off it will only put the set into stand-by mode. In many cases if the TV is in stand-by mode, and then switched off, when the set is turned back on, it will still be in stand-by mode, and will need to be turned on with the remote. (even if you unplug, in some cases) All TV's are different, so will operate differently of course.
Sylvania... | Answered on Jul 17, 2020
Sylvania 6313CB 13 in. TV/VCR Combo Logo
23 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
looking code sylvania tv vcr combo
  • Televison & Video
