Robot Coupe CL30A Food Processor Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where in ireland can i purchase a blade of my robot coupe. Or can i only get online?
EugenesDIYDen
Level 3:
Guru:
  • Master 479 Answers
  • Posted on Jul 15, 2011
EugenesDIYDen
Master
Level 3:
Guru:
Answers
479
Questions
Helped
328602
Points
1212
You may be able to get it here:
http://www.nisbets.ie/products/AdvancedSearch.asp?keyword=cl30&x=64&y=5&PageSize=50
The part isn't listed but if you ring them they might be able to order it in.
Robot coupe 3b wiring diagram
Wiring diagrams are in the back of the manuals after the parts lists.
https://www.partstown.com/robot-coupe/blixer-3b/parts#id=mdptabmanuals
I purchased a Robot Coupe R101 and wanted to add the Pulse button. Do I just get a R101 Plus switch and front panel? How hard is the replacement? Thanks
To add the pulse button to your Robot Coupe R101, you will need to purchase the R101 Plus switch and front panel. The replacement is relatively simple and can be done by following these steps:
  1. Turn off and unplug the Robot Coupe R101.
  2. Remove the screws that hold the top cover in place and lift off the cover.
  3. Locate the control panel on the front of the machine and remove the screws that hold it in place.
  4. Carefully remove the control panel and disconnect the wires from the old switch.
  5. Install the new R101 Plus switch onto the control panel and connect the wires.
  6. Replace the control panel onto the front of the machine and secure it in place with the screws.
  7. Replace the top cover and secure it in place with the screws.
Once the new switch and front panel are installed, you will have the pulse button on your Robot Coupe R101.
I have a Robot Coupe Blixer 4 V series A. The blade is stuck causing the "bowl" to not unlock and come off.
Pour penetrating oil down the upper shaft if possible. Remove the allen scews from the base with 5/32 T handle wrench. Remove the round snap ring on the motor shaft. Use vise grips or channel lock to secure the shaft. Twist the blade off and inspect it. It most likely will need to be replaced as the key that slides on the shaft will have deteriorated.
1helpful
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
1helpful
Robot coupe r 301 ultra
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
2helpful
How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. [email protected]
2answers
Top Robot Coupe Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
