In my experience, you have to open up the laptop and see if the stereo jack can be seen openly or if it is enclosed in a solid plastic block.
If it is open, you can usually bend the leads back into place where the negative will get in better contact and make the connection to the headphone.
It it is enclosed, you'll have to remove and replace it with a little soldering of a few small connections to the motherboard. You can find a replacement online pretty inexpensively in most cases.
This is a simple repair n both cases but getting the laptop open is what takes the most time.
Another solution is to get some bluetooth speakers or bluetooth headphones and add a USB bluetooth adapter if it doesn't have bluetooth.
Another way is to open up the laptop, take out your wireless card and replace it with a combo wifi/bluetooth card. You can get these often for under $15 and you'll need to buy the antenna too (Black is wifi white is BT) for few bucks. Make sure you get the same type of card (mini PCIe, M.2, etc) and the side benefit is that you might get a faster wifi at the same time.
SOURCE: small headphone jack on crap headphones from Brookstone.
i used a cellphone adopter when my headphones broke.
SOURCE: Toshiba satellite laptop
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
SOURCE: My headphone jack doesn't work on my iPod...
i had have the same problem.....but im tolazy to go to the stor and let is fix ......but i found a solution....my right earphone didn't worked only if i applyed preasure but i thought the jack doesnt make good contact so i put around the jack some aluminum foil and putit inand iwork perfect:P!!!!!
SOURCE: my zune plays music but i cant hear it.
@ tp984 If your Zune was submerged in juice (or any other liquid) it is likely liquid damage. Unfortunately you are probably out of luck. You can always try the old putting it in a bag of rice trick, but it is probably too late for that.
