Sounds like T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
SOURCE: 8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
SOURCE: i have a sony bravia lcd tv of 32 inches bearing
This seems like a T-con board problem as its responsible for several picture functions including color convergence. Or it could be a bad LVDS cable (inside the TV) I can ship you a new T-caon board for $150.00 or take it too your local shop repair shouldn't cost more than $250.00....
http://tvtechwork.webs.com/
SOURCE: The picture on the screen
HI:
This is due to a faulty digital board, your board has failed replacement is the only option.
