SOURCE: my ford focus tdi 2003 cant select 1st,3rd or 5th gears.
Car is in limp in mode unless you have the tools to work on automatic transmission you will need to take it to a transmission shop. Of course you can check oil level but I suspect you have other issues.
SOURCE: 5th gear went out yesterday
time to put a new tranny in that jet most of the time it costs to much to repair it then replace it i have done may tranny rebuilds and replacements to me i would just tell you to replace it at least you will get a better warrentee and stuff
SOURCE: 02 SATURN 5 SPD WILL 1ST AND 2ND GEAR WILL NOT
get yourself a saturn shifter bushing repair kit and install it. look on eBay, they cost less than 20 bucks
SOURCE: no 1st,2nd,3rd,and reverse gear,but have
You don't say what year, make or model your Chevy is, so I can only give your a general answer.
I assume the you have a floor shift manual 6 speed transmission. The most likely problem is a broken shift actuator rod in the transmission.
The shift handle goes into the top of the transmission. On the end of shifter there is a ball or rounded end. The end goes into three or four slots on the top of the gear case. Each slot is connected to a rod that controls a particular set of gears. ie 1-2, 3-4, 5-6 and reverse is by itself. Moving the shifter left and right select which slot the shifter controls and the forward-back moment selects the gear.
On some model cars the top or the gear case can be accesses from inside the vehicle by removal of the rubber boot around the shifter. There is a small chance that the repair could be made without removal of the transmission. The problem could also be major if the internal gear (packs) or bearings are damaged. In either event, you will need the services of an experienced transmission mechanic.
I hope this helps, If you can leave a further question in the comment, perhaps I can give you more information. Good Luck.
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr
Spock said: "An ancestor of mine maintained, that if you eliminate the
impossible, whatever remains, however improbable, must be the truth."
