Your drive belt is slipping dear. You'll need to pull the bottom cover off and replace it. Belt are sold here: http://www.amazon.com/Sunbeam-056386-Oster-breadmaker-belt/dp/B000238A34 Servicing Your Automatic Breadmaker For best results perform the following services annually. Warning: Use only Lock-Ease Graphited Lock Lubricant for the following services. Other lubricants tend to damage the seal and/or gum-up the drive shaft. To purchase your squeeze-bottle version of Lock-Ease Graphited Lock Lubricant go online or visit your local Ace Hardware or NAPA Auto Parts Store. Lubricating the Pan Shaft with Lock-Ease: Remove the bread pan insert and place it upside-down. Apply Lock-Ease to the top of the pan's coupler. Gently rock and rotate the coupler to allow for penetration. Repeat 3 times. Allow to air-dry 1 hour. Wipe away any remaining residue. Lubricating the Wheel Shaft with Lock-Ease:
Also perform these services for best results:
Access the electric motor/drive wheel platform. Check that the screws securing the electric motor to the platform are good and tight. Do not lube the electric motor.
