Malber WD1000 Front Load Washer/Dryer Logo
Posted on Jun 07, 2011
Hi, 1) I need a new Capacitor for my Malber WD 1000 washing machine. Can I order that from you ? How much is it ? 2) The dryer is not working - is there a way for me to troubleshoot to find out what the issue is ? Thank you, Michael
cormiemark19
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Jun 07, 2011
cormiemark19
Contributor
Level 1:
New Friend:
Answers
41
Questions
Helped
9051
Points
67
Hi there you say you need a new capacitor i would assume your motor is not operating .you should be able to get a new capacitor from any elec strore the size is stamped on the side ie 8uf 10 uf etc hope this helps
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Where to get parts of malber wd 1000 washing machine
The Malber service center number in NYC is 718-767-7396. Try calling them to find out where you can get parts. Hope this helps
Burned out wd 1000 motor, is there a cheap fix? Don't want to move and don't want to spend for new.
it is impossible to fix it because you said that is already burn out and for its only two things
1. is to buy a new motor
2. is to rewind the motor. this is the cheaper.
I have a Malber WD 1000 and need to replace leaking drain hose.
The malberusa website has a phone number for New York. Try there. I think the office is in Garden City, LI
Good luck.
1helpful
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
8helpful
2answers
MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
3helpful
2answers
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
2answers
Dryer doesn't dry clothes, doesn't start right after Wash
If the machine is brand new, I imagine all you want to do is check you're using the machine correctly before you claim on the warranty. Trouble is, the design of this machine is so weird, and the instructions so poor that it's easy to get it wrong. So far as I can make out from this distance, you need to have all of: Spin Cancel: Out Half Load: In Cold/Cold: In Hot/Cold: Out Cold water supply: Available Drain Hose: Connected .... and as with most condensing dryers, you need to let it run to the end of its cycle - if you take stuff out without running the final 12 minute cooldown period, everything will come out feeling a bit clammy. If those control settings don't help, try a functional faultfinding approach. To dry properly, the machine needs to do four things at once: 1. Tumble the clothes: You can see whether this is happening or not. From your description, it sounds like this is working. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 2. Blow hot air over the clothes: You should be able to hear the fan running, and if you open the door, the air which comes out should be quite warm. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 3. Condense the moisture out of the circulating air: If this isn't happening, the clothes don't get any dryer - they just get increasingly hot. Before making a warranty claim, all you need to do with this problem is ensure that the supplies and settings are such that cold water (and only cold water) is getting to the condenser. 4. Pump out the condensate: If you've just washed successfully, this is probably going to be working fine. If not, then you'll start to see the drum slowly filling with water. If this happens, check the filter (p12 of the manual), then get the warranty claim going. Welcome follow-on questions or news on how you get on posted as a comment to this query. A.
Top Malber Washing Machines Experts
vince
john h
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
