SOURCE: Garmin ique3600 stuck in the calibration screen
Give the screen a thorough cleaning with a soap and water cloth (NOT SOAKING) and allow to completely air dry. Then try recalibrating.
SOURCE: garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
SOURCE: nuvi® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
SOURCE: When I turn on my
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
//changed this line from 'solution1description.innerHTML' to use getElementById
//to prevent FF warnings. They both appeared to work, but this is cleaner.
solution = document.getElementById('solution1description').innerHTML;
Last modified on: 09/30/2010
