I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps. Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check you hard drive to make sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption and then restart your computer.
Technical information:
STOP: OXOOOOOO7B (OXF78D2524,OXCOOOOO34,OXOOOOOOOO,OXOOOOOOOO)
what can I do in details please
Re: I open my new laptop (Toshiba) when i try to boot the...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Restart the laptop and try logging back in using the new password.
Log on without the Windows XP installer. If you don't have a Windows bootable CD, use another computer with internet access so you can create an emergency recovery disk (ERD) that will allow you to unlock a Toshiba laptop. Browse through the internet and search for ERD software.
Burn the ERD program into the blank CD and use it to reboot the Toshiba laptop that you want to unlock. The computer will automatically detect the program, so it will take you to a series of prompts where you can change your password.
How to reinstall Windows XP operating system or installing fresh copy of Windows XP on your computer.
If your Windows XP operating system had problem due to corrupted files, viruses problem or you want to upgrade your system. This procedure will guide you in reinstalling your current Windows XP or installing fresh copy.
After this installing process, you need all your hardware drivers like Chipset Intel driver, LAN driver, Sound driver, WAN driver, Webcam driver and others for the computer to be fully operational. Otherwise, do not proceed on reinstalling you operating system if your do not have those hardware drivers.
CDROM drive is required for installing Windows XP. If you don't have in your notebook computer, use external CDROM drive to connect in your computer using a USB cable.
1. To start with, you need to back up your in blank CD all your important files before you begin installation produre because all the data will be wipe out.
2. When ready, start your computer and when booting press F2 to BIOS setting.
3. On BIOS menu, choose the BOOT setting and change the priority boot to CDROM, exit and save.
In some laptops, you can skip this BIOS setting process by repeatedly pressing F9 key or F10key when booting your computer and it will run boot priority on CD.
4. Once you exit from BIOS, you computer will reboot and a message will appear " Press any key to boot from CD", press any key to enter into WINDOWS XP SET UP.
5. Belows instruction messages will appear:
* To set up Windows XP now, press ENTER * To repair Windows XP installation using recovery console, press R * To quit set up without installing Windows XP, press F3
Press ENTER to initiate the installation.
6. You will go to Windows XP license agreement and press F8 to agree.
7. You will ask you if you want to REPAIR or REINSTALL the operating system. It will appear like this. Just press ESC to proceed.
A. To repair the selected Windows XP installation, press R. B. To continue installing fresh copy of Windows XP without repairing, press ESC.
From repairing your operating system, it will not removed all your files and other software installed in your computer including your hardware drivers installed. Just fixing the operating system.
For reinstalling the operating system, you need to back up all you files because it will wipe out all you datas in your computer.
8. After that, it ask you where partition you want to install the operating system. The message will display like this :
C : Partition1 [NTFS] D : Partition2 [NTFS] Unpartitioned Space
Use the directional key to navigate and choose C: Partition1 if you want reinstalling Windows XP and press enter.
If you want clean copy of Windows XP, you need to delete both partition by pressing L and install clean copy at Unpartitioned space. By these procedure, you will have C: drive only. D: Drive is delete.
9. After choosing the desire partition. this will appear :
* Format the partition using NTFS files system * Format the partition using the NFTS file
I suggest to choose the first line which is the quick format. The 2nd line take too much time to install the operating system. Press to initiate the installation and it will be finish and reboot automatically. PART OF WINDOWS INSTALLATION IS FINISHED.
If you had interrupted installation which is asking for certain driver file, your CD installer maybe damage which cause files to be unreadable. Try to replace the new Windows XP installer CD to proceed and until finished installing OS.
10. Once it reboots, this time do not boot from CD or do not press any key to go to PART2 OF WINDOWS XP INSTALLATION PROCESS.
11. On the opening, regional and laguage option will appear, jus click next.
12. The it will ask to type your name & organization. Put you name and company if any and click next
13. Then, it will ask for CD key and type the 25 character CD key and click next
14. Then it will ask for computer name. You can change or leave it and click next.
15. Then, set your date and time zone and click next.
16. Then, it will ask you for workgroup and computer domain, just leave it and click next.
17. Now wait until the installation process end and it will again restart automatically.
18. Again, do not boot from CD and display setting will appear. Just click OK.
19. welcom to Microsoft Windows screen will appear. Just click next.
20. Helps protect your PC will appear and choose Turn on Automatic Updates ( Only if you install genuine Windows XP). Otherwise, I suggest to choose "Not right not" if you are installing copy only of Windows XP.
21. Who will use this computer message will appear. Just type your name on the first box and click next.
Also for your reference, here is the video for your convenient .
A thank you message will appear, Just click next and it is finished.
I hope it helps you and thank you for using FixYa !
For repairing the operating system here is the blog as other want it.
As per others demand, here is the video for Windows 7 and Windows Vista Operating system
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Try pulling the battery out for one minute and then put back in.
If this doesn't work, try tapping on F2 when the computer starts up. Check the BIOS and make sure that "keyboard" is being detected.
Lastly, connect an external keyboard to the laptop to see if it will at least boot to windows. Once in windows, perform a system restore to the last time it was working correctly.
doesn't the toshiba website provide the drivers for you to download? Can take a bit of searching but most of the large computer manufacturers do have this facility.
Boot the computer using the XP CD. You may need to change
the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the
BIOS and change the boot order.
When you see the "Welcome To Setup" screen,
you will see the options below
This portion of the
Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter
to start the Windows Setup.
To Repair Install, press ENTER \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" />
do not choose "To
repair a Windows XP installation using the Recovery Console, pressR", (you
Do Not want to load Recovery Console).
I repeat,
do not choose "To
R".
Accept the License Agreement and Windows will search for existing
Windows installations.
Select the XP installation you want to repair from the list and press R
to start the repair. If Repair is not one
of the options, END setup. After the reboot readWarning#2!
Setup will copy the necessary files to the hard drive and
reboot. Do not press any key to boot from CD when the message
appears. Setup will continue as if it were doing a clean install,
but your applications and settings will remain intact.
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
