Hi there aldao62367
if the oil level is at correct level , check that the tank breather in the fuel cap is clear
then change the oil it may be thinning out , and low oil sensor float is not floating and makes the unit think its got a low oil problem - shuts down, also check for a tight valve ?
off the top of head valve clearance for inlet 0.005 thou and ex 0.007 thou
change oil to a 20w/50 or 10w/ 40 oil
should hold about 1.0 litre
cheers pauly46
