20 Most Recent 13 HP Engine GX390 OHV Horizontal Shaft Questions & Answers
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
13 HP Engine... | Answered on Jan 29, 2019
Start by changing plug. Make sure to ground plug to engine when testing for spark. After go after cable. If resistance is on you'll need to check magneto or coils
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
13 HP Engine... | Answered on Jan 24, 2016
loss of power with blue smoke means the engine is using oil and possibly getting ready to seize up. Pull the spark plug and see what color it is, if it has small flecks of metal then the piston is scored. When was the air filter replaced and how does it look, entry of dirt will destroy an engine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/darryl_24e8d8d43e609e3c
13 HP Engine... | Answered on Oct 06, 2015
have to pull the cover and flywheel..
13 HP Engine... | Answered on May 06, 2015
If its on the compression stroke when you are pulling it will be hard to pull it, because you're fighting against the compression of the engine, make sure the valves are at the correct position and not fully closed when you are pulling.
13 HP Engine... | Answered on Mar 04, 2015
15 seconds it is running out of gas. check flow from the tank.
13 HP Engine... | Answered on Dec 26, 2014
Check that the fuel tank is not creating a vacuum. this will starve the engine. After it shuts down the vacuum dissipates and lets the fuel run into the carb again.
13 HP Engine... | Answered on Apr 18, 2014
have you checked the engine oil. most models have an oil motion pick up. they are fitted to most lawn mowers as well when the oil gets week it does not lift and engine will just cut out. replace oil with 20/50 oil.
13 HP Engine... | Answered on Oct 21, 2013
https://www.youtube.com/watch?v=aRPmRBlqRqM
https://www.lindec.com/download/14043667571_Honda_GX630-660-690-workshop_manual.pdf
Honda Vehicle... | Answered on Mar 26, 2020
Gravity feed tank need no fuel pump.....
Honda Vehicle... | Answered on Aug 26, 2019
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Honda Vehicle... | Answered on Feb 06, 2019
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
Honda Vehicle... | Answered on Jan 29, 2019
If it is an electronic accelerator pedal you have, perhaps poor contact on the wires/connector on the pedal. Lay down on the floor, and check if the connector is in it's place and no loose cables. I had same problems with brake pedal and signals from that one.
Honda Vehicle... | Answered on Nov 01, 2017
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
Honda Vehicle... | Answered on Feb 10, 2017
13 HP Engine GX390 OHV Horizontal Shaft Logo
15 questions posted
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Vernon Taylor
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Vehicle Parts & Accessories
Most Popular Question
no spark new coil new plug no ground
  • Vehicle Parts & Accessories
