Master
- Posted on May 16, 2011
Re: Outside unit is running however it is not cooling.I...
Sounds like there is a Freon leak and has been since it was installed and is going off on because of low charge, you will need to call a competent A/C repairer, more then likely the leak will be in the air handler, should cost under a $100 to fix. Good Luck Tim
It was a little low when it was installed.They are coming back to finish charging.However the unit is not short cycling.It has been running fine now for almost 24 hours.But it will quit its just a matter of time.Thats what is puzzling them and me.Once it quits all there is to do is shut off the power and turn it back on.Its like its resetting something.
