Yamaha Sk88 Keyboard Survival Kit For Ypg625 And Ypg525 Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reboot instructions for a Yamaha YPG 625 piano? One fingered chords won't function, nor will the sequencer start from the keyboard. Thanks! ****
Fred Yearian
Level 3:
  • Yamaha Master 5,603 Answers
  • Posted on May 04, 2011
Fred Yearian
Yamaha Master
Level 3:
Answers
5603
Questions
Helped
2250511
Points
16163
Read about initialization on page 61 of your user manual. This is a factory reset. There are two procedures there. If you don't have the manual download it here:
www.yamaha.com/yamahavgn/.../ypg_525_eng_manual.pdf
tip
YPG625 Humity problem
The overal sound of yamaha YPG 625 and keys operation are exellent by the price. The only problem I eperienced is the instrument operation under high humidity environment. Under this condition many keys sound loud over others, furter more with no expectation from mucisian. This problems is normal for that model because the music store change my previously YPG625 for the same problem<br /> <br /> Sometime I solve the problem to located the instrument under sun exposure and cover the keys and display to avoid direc sun exposure.<br /> <br /> Another is apply with a hair dryers over the keys. But is very disconform situation, and I dont know if the Yamaha exposed this isntrument under high humidity environment durig the product test. I has a Ymaha very low budged digital piano and Roland controller A33 in the same condition and never eperience problems, only with this model.
Why is there no sound
main board problem.. faulty ic.if all oher functions are working..on the main board change ic number ak4385 DAC
Rattling keyboard
Call Yamaha at 714-522-9000 to find local dristubators/ liscend yamaha dealers. You may also visit the yamaha website.
No sound on one key
That's very annoying! The keys press on to a contact strip running the length of the keyboard. Over time this wears out and notes can either stop being dynamic or stop playing altogether. You can buy the strip off ebay and have a go replacing it yourself - not too expensive. I paid someone 50pounds to supply and fit one to a 61-note keyboard.
No power. voltage converter putting out 13 VDC. ON/OFF switch works. Any suggestions?
Inspect if the power input socket of The keyboard it may have a loose soldering or a cold one in one of the tips and may need to be
resoldered
I asked for help on a Yamaha keyboard. The solution was posted on an e-mail address that is not accessible. What do I do to either get my solution or get my money back
I don't know what the original problem was but here is your service manual:
http://elektrotanya.com/yamaha_dgx-620_ypg-625.pdf/download.html
Scroll down to "get manual" and click on it to download a PDF file of the service manual.
Ignore other download links for viewers etc... If you have trouble, contact me at fredy2 at aol.com with YPG in the subject line.
Hello, i spilt some smoothie on my Yamaha YPG-625s keys. The keys sound better now but i just want to properly clean the inside. How can i do this?
It is a lot of work to open and access the key contacts. Here is your service manual:
Scroll down to "get manual" and click on it to download. Ignore other download links on the page as they are for viewers and other software.
2answers
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 • Casio Music
2helpful
What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
