It's fairly easy to do (unlike Ducane Grills). To help you, I have included a link to your Owners Manual, which will really help you. Go to the Maintenance section, Page E-1 for the drawings and description of how to remove the burners.
http://help.weber.com/manuals/pdf_files_2011/Gas/Summit%20SilverGoldPlatinum/OwnersGuides/Summit_SilverGoldB_LP_OwnersGuide_43720_012903.pdf
Hope this helps you to "Get 'er done!"
Happy Grilling!!
SOURCE: some holes are plugged on burners and i need to clean
Use a stiff wire brush on the burner tubes to loosen debris. Use and up and down motion. I've also used a bent safety pin to clean out each hole individually which is very tedious and time consuming. You may have to disassemble the gas burners to get to the burner tubes, but Webers are farily easy to take apart and then put back together again.
SOURCE: where can I buy Weber summit platinum D6 burners?
Call Weber direct
I have called them for my grill and they have always been wonderful
