Computers & Internet Logo
Posted on Apr 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bios password for toshiba satellite M100 - Toshiba Satellite M100 Notebook
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on May 14, 2011
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833754
Points
6040
You can reset the BIOS password. To do that read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 • Computers & Internet
Hi i need the bios(bin file) for toshiba satellite m100-164 please help me refards saeed
Hello Friend
Just Go to TOSHIBA Website and click on Download tab and enter your product model number to search bar and download bios file from the list.
I have a toshiba portege m100 with a bios password set that i need to bypass. toshiba want 80 quid just to look at it. some sorces say short clr1 jumper but i cant find it on my machine. please help.
Most DESKTOP computers have a jumper to "clear CMOS settings",
but most NOTEBOOK computers do NOT have that jumper.
The password exists to protect the owner of the computer, should a thief be trying to use the computer.
You probably can remove the disk-drive, and copy the files onto a new computer, if you don't want to pay TOSHIBA to bypass the password.
WHAT DO I DO TO PUT A PASSWORD ON NOTEBOOK
When the notebook is loading, select the BIOS menu. Within the BIOS you will find the page with passwords on it.
Don't forget if you put a system or master password on it and forget the password, it is extremely difficult to et back into it!
Hope this helps.
Iv got a toshiba m100 . which crashed...now asks me to enter password ...where can i find this?
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Daigonishing and solution for satlite m100
flash the bios.
get the dvd drivers from toshiba website
BIOS Password
Some passwords are listed here:
http://www.timesonline.co.uk/tol/life_and_style/article510252.ece?token=null&offset=12
Note: For Toshiba BIOS, try this:
Hold down the Shift key as the computer is booting.
Other suggestions are here:
http://www.computerhope.com/issues/ch000235.htm
Toshiba satellite m100-jg2
Alf, you are asking about multiple issues with different computers in the same thread and also requesting off Forum help via email. This is just confusing and I don't see any way to help you other than pointing this out.
Good luck.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
