You'll need to remove screws that are by the door handle,
arm rest, under door and side of door and then gently pull back on the
panel as there will also be retaining clips attached and you don't want
to break them. If needed, you can pull back the weather seal
(can't reuse it, but it's not that important) and you will be able to
access everything inside the door
Sounds like it is a broken window regulator. You will need to remove the door panel to fix it. Mine broke and I can actually pull the window up and it will stay until the vibrations of the freeway eventually make it slide back down again (this would be a temporary fix of course). Anyways, there are a couple screws behind the door handle I believe, and then some snaps around the edges, and some clips along the window line. You should get a Bentley's manual so you know exactly how to fix the window regular.
Hello, VW polos 1.0, 1.4. 1.6, suffer from carbon bulid up in the throttle bodys causing bad idling, esp the Bosch Mono-Motronic (Throttle Body Injection systems), a good clean with carb cleaner should repair the problem, also engine temp sensor replacement and idle speed control valve replacement can help idle problems.
