From what i could find on your case you can put 2 extra 80mm fans in. some things you want to look at when you buy fans is that they have power plugs that work with your power supply. the old white molex are the most comman type . So if your power supply has only the new black serial plugs you will need an adapter. the next thing you need to look for is noise level. most fans will list a decible level "Db" the lower the better. generally the lower the rpm the quieter the fan. case fans use special screws so make sure some come with the fan. Newegg.com is a great place to buy computer parts.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
