Check your transmission output shaft speed sensor. First check that the connector is clean, free of corrosion, secured firmly and that wires have good insulation. If all looks well at this point then disconnect the speed sensor, remove it and clean its tip of any debris and see if this clears the DTC. If not change the sensor for a new one (less than $30). This should fix it.
