Possible causes
- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
What does this mean? Tech notes
The P0455 it's a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
What does this mean? When is the code detected?
Evaporative Emission System (EVAP) control system has a very large leak such as fuel filler cap fell off, EVAP control system does not operate properly.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors
P0455 Mitsubishi Description
This diagnosis detects leaks in the Evaporative Emission System (EVAP) purge line using engine intake manifold vacuum. If pressure does not increase, the Engine Control Module (ECM) will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition.
The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
Read more:
http://engine-codes.com/p0455_mitsubishi.html#ixzz3NlVyARyX
this has po449 and po455.
