Belkin Basic Wireless Router Logo
Posted on Apr 12, 2011
Hi there, i can't install my updates for belkin Share wireless router, during the installation it keeps rebooting my computer...
Anonymous
Level 1:
  • Contributor 252 Answers
  • Posted on Apr 12, 2011
Anonymous
Contributor
Level 1:
Answers
252
Questions
Helped
90981
Points
34
What do you mean by installation? Are you trying to upgrade the firmware on your router and are you going through the Belkin Router Manager icon in your system tray (right-click/check for updates)?
Also if you already downloaded the firmware update, make sure you update from a directly connected computer and not over wireless.
As far as the rebooting goes, if that doesn't help then depending on your Operating System if it's windows, you can check the event viewer to see what error is being reported. Go to Start, click Run and type eventvwr.msc then press Enter. Under Applications or Applications and Service Logs, you should see a recent error for the application. That will lead us to why it's rebooting.
tip
To get rid of multiple issues with belkin routers
To resolve the issue with Belkin routers:The routers that are released recently by Belkin Inc., are Basic / Connect N150, Surf / Surf N300, Share / Share N300, Share Max / Share N Max300, Play / Play N600, Play Max / Play N600 HD
  • These routers comes with a software CD.
  • Belkin router monitor is the software that gets installed in the computer when you run the setup CD in your computer.
  • This software is really an unwanted one that takes around 30 minutes to get installed in your computer.
  • In addition to that, this software displays unwanted popup messages.
  • 90% users are not aware that they can use the routers without installing any software in their computers.
Inorder to make your router properly, these steps has to be followed...
  • The belkin router monitor software has to be uninstalled from your computer.
  • Firmware of the router has to be updated to the latest version available from the belkin support site.
  • Self healing feature of the router has to be disabled.
  • Wifi protected setup (WPS) has to be disabled.
To uninstall the belkin software:
  • For Xp computers, Goto control panel > Add or remove programs > select belkin setup and router monitor and remove it.
  • For vista & win7, Goto control panel > Uninstall a program > select belkin setup and router monitor and remove it.
To update the firmware for your router:Goto http://www.belkin.com/support/
  • Select your router and download the firmware for your router. The file with a .bin extension will be downloaded to your computer.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router http://192.168.2.1
  • Belkin router setup utility will be displayed.
  • Login to the page. (password: leave it blank and click submit)
You will have the status screen.
In the status screen, you will have the very first box in the centre of the screen says "version info", under that you will have firmware version.
Just note down the firmware version there. If the firmware version in router is lesser than the one downloaded from support site, then the firmware has to be updated.
On the far left side below the Utilities you will have "firmware update", you need to click that.
Now on the right hand side you will have "browse".
Click on browse and locate the downloaded .bin file from your computer and click update.
Click ok for all the warnings.
You may see a count down now.
Once its done you will be brought back to the status screen.
Login to the router again with a blank password and click on restore factory defaults below the utilities and click ok for all the warnings.
Now the firmware of your router must have updated with the latest version.
To disable Selfheal:
On the far left side below the Utilities you will have "self heal", you need to click that.disable the self heal and apply changes.
To disable WPS:On the far left side below the Wireless you will have "wifi protected setup", you need to click that.wifi protected setup will be enabled by default, disable it and apply changes.
Click here to learn more about wps...
How to install my belkin n150 wireless router on my netbook that has no built-in CD-Rom?
HI Gilbert,
Can i have the brand name of the modem , Your Internet service provider name , so that we can configure the router with using the CD.
We have another method to configure the router that is manual configuration method.
Thanks & Regards,
prema
Hi. I have just set up a Belkin Share wireless router, Connecting to internet fine, but can't get printer to work via usb. Green light above socket doesn't come on when I plug it in. Thanks in advance -...
Ian, you have to 1st of all connect that printer to the computer and check if its working fine or not. Check if you have installed the necessary drivers and software that came along with the printer. Once that gets to go, then, connect the printer to Share router and check if the light above the USB is lit up to check if the port on router is working. If that is lit, you have to be connected to the router (make sure that you aren't connected wireless as a guest). Guest access doesn't have the rights to have file and printer sharing! Install the router monitor software properly that would be on the disk which came along with router or download the latest version of software from: http://en-us-support.belkin.com/app/answers/detail/a_id/3714/p/5132
You also have a brief tutorial on how to configure a printer with this router on the Belkin Support website. Here is the link for that. http://en-us-support.belkin.com/app/answers/detail/a_id/3796/p/5132.
For further clarifications, do revert!
Thanks for asking.
Regards,
Arvind S Iyer
My belkin N router always disconnects on the internet. im sure its not a modem issue coz when i try to restart my router its connected again to the internet. my belkin router model is f5d8233-4v3....
Disconnections are generally relative to the Internet Provider and Speed. If the speed drops, the router can disconnect and reboots. Just make certain you always update all drivers and especially if you are in Windows, keep up with current updates. Check your device drivers and do update from there also.
19helpful
Can I install my belkin router without setup cd?
you may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
How To Setup Belkin Router Install Belkin Wireless Router Fixotip
Printer connection on my Belkin G Plus Mimo
You have to make sure you go to Control Panel/Printers, right click on the printer in the list and click 'Properties' - go to the sharing tab, select 'Share this printer', give it a name, and click OK. Then go to Printers on each of the laptops, select 'Add a printer', then 'Network printer', then 'Browse for printers'. You should be able to see the printer. If all the computers use the same operating system, you're good, otherwise, when you first share the printer, you may want to install additional drivers from the cd to support the different operating systems - alternately, you'll have to install the drivers for the printer on each computer.
Please rate if this helps :)
10helpful
Belkin n wirelss router setup
To setup the router you will need to log in to your router's control panel. This certainly won't be as simple as on the installer disc, yet it is still do-able. You might also want to contact Belkin's free technical support hot line. They can help you set it up with the method I described above.
1helpful
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
