Bose is premium gear at premium prices so it isn't wise to take chances - you should contact Bose to obtain a connection diagram and then you could find it isn't suitable to use the existing Audi wiring and you should wire afresh from scratch. Obtaining an Audi diagram will help or perhaps a connection diagram for the original sound system.
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
SOURCE: Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
SOURCE: Audi 2001 Speaker
So, I dealt with this problem on my own. It would have cost me over $350 to change a stinking bose speaker in my A4, instead, it cost my $62.50 and a saturday afternoon.
Here were my symptoms:
On really cold mornings or days, my passenger side front door speaker would crackle, not exactly blown per se, but it was really annoying, making me adjust my balance 100% to the right side. But, when it warmed up a little later in the day, the crackling would go away. I'm guessing this had something to do with expansion and contraction due to heat, or lack thereof.
Here's what I did:
I called around and found out that you can buy replacement speakers from the audi parts shop at your local dealer... they said it would cost $178.00 for one speaker! I understand it's Bose, but come on, it went defective on me. So, just like you said, I checked ebay. I was able to get, not one, but two used replacement speakers for 60.00. But I was concerned about dismantling my door panel. I've been in a lot of cars where the interiors rattles because of custom or even professional installation jobs. I didn't want to lose my wonderfully noise free interior in my car. I figured I need some directions: I checked the internet and found this site: carstereoremoval.com. What do you know? They give you simple step by step instruction on how to remove a door panel on a 2001 A4. It cost me $2.50 through paypal. So total, (besides the torque wrench), 60.00 + 2.50 = 62.50 vs. 350.00. That's a lot of beer money! Hope this helps someone else out.
Be forewarned: To replace the bose speaker you need a T20 torque wrench. I didn't have this and was caught having o drive to home depot without a door panel.
SOURCE: Audi A4 Radio Concert, can
there are usually two buttons to push simultaneously for two or three seconds...
SOURCE: blu-ray + bose 3-2-1 system connection?
Connect an HDMI cord from the bluray player to a free input on your HDTV. Then connect the standard WHITE/RED stereo cable from the bluray player into the AUX input in the back of your 3-2-1 system and voila!
You may need to check the configuration of your bluray player to make sure that is outputting stereo audio, for this please refer to the player's user manual. Other than that, you should be alright.
