It might be residue from oil leak repair, I'd keep an eye on it for 1-200 miles and check levels regularly. Or another oil leak...
SMOKE UNDER HOOD COULD BE COOLANT LEAK FROM RADIATOR ITSELF OR CHECK FOR LEAKING TOP RADIATOR HOSE AND CHECK FOR LEAKING BOTTOM RADIATOR HOSE.LOOK UNDER THE HOOD IF COOLANT BOILING OUT COOLANT OVERFLOW JUG ENGINE OVERHEATING FROM BAD THERMOSTAT OR BAD WATER PUMP.CHECK FOR COOLANT LEAK AT WATER PUMP WEEP HOLE.IF SO WATER PUMP NEED REPLACING.ADD MORE COOLANT UNTIL LEVEL CORRECT.TRY LOCATE LEAK. IF CAR OVERHEATED AND BOILED IT OUT. SMOKE UNDER THE HOOD CAN ALSO BE CAUSED BY LEAKING VALVE COVERS WHICH CAN BE FIRE HAZARD IF OIL LEAKS ON HOT EXHAUST MANIFOLD.
