Intel D845GVSR Motherboard Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Intel D845GVSR motherboard. The 4 back USB ports are enabled but the two front ports aren't. I also have a Creative Combo NS DVD ROM with card readers in it. My Computer guy enabled the card readers in the comboNS and disabled the front USB ports. Can you tell me how to disconnect the card readers and connect the front USB ports. Thanking You, A friend in need
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
2936
Points
70
This is probably set in the BIOS. You need to reboot the computer and enter the Setup/BIOS to enable the ports. Otherwise they're physically disconnected in the case and you will need and expert to reconnect.
Mirca Sekosan
Level 2:
  • Expert 134 Answers
Mirca Sekosan
Expert
Level 2:
Answers
134
Questions
0
Helped
22872
Points
398
Simply just find the cables from your front USB panel, then take a look at your card reader and follow the cables to the motherboard, replace and enjoy. Or take a look at the manual: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVSR
Anonymous
Level 3:
  • Master 356 Answers
Anonymous
Master
Level 3:
Answers
356
Questions
0
Helped
89307
Points
1141
1) turn off computer
2) move bios jumper to maintenance
3) turn on computer and hit F2 to get into bios settings
4) go to advanced, enter usb configuration and enable, exit and save
5) power off computer move jumper back to original setting
6) reboot, should be good to go.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
How do i hook up usb button in intel 845 motherboard
Well, that's a start. You know you have an Intel motherboard in your eMachines, that uses an Intel 845 motherboard chipset.
It is an Intel D845GVSR motherboard.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would advise upgrading to Adobe Reader X { 10 }, however, if you don't have it )
After you click on the above link, it may take up to 30 seconds before the first page comes up. (Took 6 seconds just now. Adobe Reader X, and medium speed DSL connection)
At the top of the PDF file, is the PDF file page number box.
It is to the left of the Down Arrow.
Go to Page 11.
T is the Front Panel USB header.
This is where the USB ports on the front of the computer, (Front Panel) connect to.
Go to Page 31.
E is the Front Panel USB header.
The Front Panel USB header is J9F2.
Observe the numbers next to the pins.
Go to Page 33.
This is the pinout for the Front Panel USB header, using those contact pin numbers.
1, 3, 5, 7, and 9 = one USB port
2, 4, 6, 8, and 10 = one USB port
Notice pins 9 and 10 are not used.
You can connect two USB ports to this header.
The pinout of ANY USB connector, female, or male, is set to a Standard.
This is the standard pinout for USB connectors,
http://pinouts.ru/Slots/USB_pinout.shtml
In case you cannot download the Intel D845GVSR motherboard manual;
Looking at the motherboard in it's normal position, installed into the computer case, the USB header is on the Bottom edge of the motherboard.
It is to the immediate Right, of the bottom white PCI slot (PCI 3)
It is to the Left of the motherboard mounting hole.
It is Below the Intel 82801DB, Southbridge chip.
Two rows of pins.
5 across the Top row, 4 across the Bottom row.
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Top are numbered,
Pins 2, 4, 6, 8, and 10
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Bottom are numbered,
Pins 1, 3, 5, and 7
Pins 1, 3, 5, and 7 = One USB connection
Pins 2, 4, 6, and 8 = One USB connection
Pin 9, and Pin 10 are Not used. (N/C. No Connection)
A) Pin 1 is for Power
B) Pin 3 is for D-
The Data, or Signal wire. It is the Negative connection
C) Pin 5 is for D+
The other Data, or Signal wire. It is the Positive connection
D) Pin 7 is for Ground
Going to the other USB header;
A) Pin 2 is for Power
B) Pin 4 is for D-
C) Pin 6 is for D+
D) Pin 8 is for Ground
For additional questions please post in a Comment.
Out of curiosity which eMachines is this?
Regards,
joecoolvette
My model is: intel D845GVSR C45963-001 and i have dvd rom of sata can you tell my is sata cable connector located? or if not tell another formula.
SATA Ports are not available for this model Intel mainboard D845GVSR.(Manual reference) You cannot use the DVDROM with sata interface on a IDE interface, but you can use a Sata to IDE adapter to connect the Sata DVDROM on your mainboard, but not recommended. Just get a DVDROM with IDE interface.
Hope it helps.
There are the characteristics of my PC Motherboard: CPU Type DualCore Intel Pentium E2200, 2200 MHz (11 x 200) Motherboard Name Biostar G31-M7 TE (2 PCI, 1 PCI-E x16, 2 DDR2 DIMM,...
slow USB (thrumb drive, reads or writes slow or both)?????
the bios all USB ports enabled firest
the USB drivers from BIOSTAR loaded forget that ??? I bet yes;
front USB2 ports and rear USB ports fail?????? or just one.
the intel ICH7 chip runs up to 10x, USB2 ports so is not a problem.
why not get working driver from BIOS STAR
XP is a virus magnet never seen one not infected now or for 10 years, XP driver seen on the web are all infected
the ones at BIOStar are good. (and microsoft.com direct)
4helpful
2answers
Sound drivers
hello, this link should get you what you need for that motherboard. also consider a add on sound card, if the one you have is trouble. alslo make sure the built in sound is enabled in the system bios. (should be by default) http://www.intel.com/support/motherboards/desktop/d845gvsr/index.htm#anchor2 good luck! please rate this solution. thanks. if you need further assistance,reply
Intel D845GVSR song play but sound does not work
here is a site for intel motherboard only
www.csif.us.ucdavis.edu/-wen/intel.html
other problems you over look and conflicks with com ports and irq's, they do teach this anymore it for old school teachers.
www.atipa.com/infosheets/irqs.
switch the wire connection if you have that option.
www.web.idirect.com/-frank/index.html this one is for cd-rom issues.
www.motherboards.org
if you need more info contact threw the web site
rod the candymangandy
1helpful
How to pick the right motherboard for eMachines T5026?
Heres what i found:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5026
Intel® Pentium® 4 Processor 519
Operates at 3.06GHz
1MB L2 cache and 533MHz FSB
Operating System: Genuine Microsoft® Windows® XP Home
Chipset: Intel® 915GV chipset Memory: 512MB Dual Channel DDR
Expandable to 4GB Hard Drive: 160GB Serial ATA 7200rpm, 8MB cache Optical Drives: DVD±RW, 16x Multi-Format double layer
CD-ROM drive - 48x max write Media Reader: 8-in-1 digital media manager Video: Intel® Graphics Media Accelerator 900 w/DirectX® 9 support
Up to 224MB shared video memory Sound: Intel® High Definition 6-channel audio (5.1) Network: Intel® PRO 10/100Mbps integrated Ethernet Modem: 56K ITU v.92-ready Fax/Modem Peripherals: Premium multimedia keyboard, 2-button wheel mouse, amplified stereo speakers Ports/Other: 7 USB (1 in Media Manager, 2 in front, 4 in back), 3 IEEE 1394 Firewire (2 in front, 1 in back), 1 VGA external connector, 1 serial, 1 parallel, 2 PS/2, 5 audio (2 in front, 3 in back
If you need to replace the motherboard, it is most likely proprietory which means it can only be from emachines so you can request an RMA at the link.
2answers
D845GVSR USB 2.0
if you are running windows xp you will need to go to www.microsoft.com and download service pack 2.
2answers
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
