We had this same problem and I just fixed it today. What is happening is either the white plastic buttons expand with time (highly unlikely) or the black plastic housings shrink with time (more likely). To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers, and sand down the edges of the white buttons to make them slightly smaller. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button in it, held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs in turn. 4. You'll now have a black base, a black surround (where the button sits), a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. 6. Reassemble and repeat for the other side. Good luck, Jesse.
