Question about Bugaboo Cameleon Jogger
Hello Am having great difficulty reassembling our bugaboo after fixing white buttons. Am aligning lower leg with the ramp inside button. When I screw it all up again the lower leg and the outside of the button move together when lower leg is pushed. But the button wont pop out (or move at all), and I cant get the seat unit back onto the pram. Pls can you tell me what m doing wrong? Many thanks!
    Guru:
  • 541 Answers
With the seat unit face down push down inside the lower leg unit with a screw driver, The white button should pop out. If it does not either the button is stuck or the locking splines on the outer sides of the button unit are not sliding freely into the spines of the outer ring. When you push down with the screwdriver your force only pushes the back of the button unit. It is the inner spring that has to move the white button and the locking splines so any burrs or roughness can stop its movement. www1.fixya.com/support/r7805137-fix_bugaboo_white_seat_buttons
Posted on Oct 19, 2011
  • Tiffany Field Oct 24, 2011
    Thanks very much Stephen
Tip
HOW TO FIX BUGABOO WHITE SEAT BUTTONS
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a Phillips. Here is the process: 1. On the other side of the white button unit is a screw. Remove it using a Phillips screwdriver.
2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver.
4. You'll now have a black base, a spring and a white button. Pay attention to how the two black parts align to each other so you re-assemble it correctly.
macnutz_28.jpg.
5. Pop the white button out of the upper black surround. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea.macnutz_27.jpg
6. Reassemble unit and check it has full movement (see photo below). macnutz_30.jpg
7.
On the underside of the button unit a ramp shape should lineup with an opening in the bottom edge.macnutz_33.jpg
8. Fit button unit back into upper seat leg, Fit lower seat leg aligning it to the back of the button unit so the push rod in the lower seat leg pushes on to the ramp on the button unit. Note the seat button will not come out and lock until the seat is fitted back on to the chassis pushing the rod up to push the button out to the lock position. Once you have fitted the back screw in you can use a large screw driver to push down the inside of the lower leg to check the white button pops out and locks. If you have any resistance dismantle again to check alignment and the condition of the interlocking teeth of the button and the outer rings. Sand of any burrs and use a little silicon grease. Reassemble and test again.
Repeat operation to the other side if necessary. Buttons are not interchangeable so doing one side at a time avoids mixing them up.
If the tabs on the white button are broken you can buy a new button unit as a part www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
on Jan 14, 2011 | Bugaboo Cameleon Jogger
Bugaboo bee pram won't fold - the white button has jammed. How do I releas it?
Not an easy fix the handle unit is all closed in with pop rivets so you need a drill and pop rivet gun just to open it. Try spraying silicon spay in to the inside of the handle where ever can then pull up ******* the release buttons while flexing the joint back and forth.
Jan 01, 2012 | Bugaboo 192 Cuddy Cabin ORDER TOD Baby...
I have a bugaboo frog stroller that the seat recline buttons are not working. They will push in, but do not pop back out. Any thoughts?
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side. If the buttons are broken you can buy them as parts www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
May 16, 2011 | Bugaboo Baby Gear
Seat wont lock into position as white buttons wont pop out
We had this same problem and I just fixed it today. What is happening is either the white plastic buttons expand with time (highly unlikely) or the black plastic housings shrink with time (more likely). To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers, and sand down the edges of the white buttons to make them slightly smaller. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button in it, held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs in turn. 4. You'll now have a black base, a black surround (where the button sits), a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. 6. Reassemble and repeat for the other side. Good luck, Jesse.
Mar 05, 2011 | Bugaboo Cameleon Stroller
How do I fix one of the frame support buttons on a Bugaboo Cameleon, as the lefthand button is stuck?
Do you mean the tilt buttons? If so you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using the phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side.
Jan 16, 2011 | Bugaboo Cameleon Jogger
My bugaboo cameleon white buttons have stopped working??
Dec 05, 2009 | Bugaboo Cameleon Jogger
Our round white buttons on our bugaboo are stuck and won't lock
we had the same problem. spoke to bugaboo and they sent a new bit. think the spring goes inside. easily fixed with the new bit.
Nov 15, 2009 | Bugaboo Cameleon Stroller
Hi, my bugaboo is now 16 months old and recently the round white buttons on the side that lock the seat into three different positions got stuck instide, so the seat is not locked in any position, which...
My daughter has just brought me a Bugaboo which is 25 months old (one month out of warranty) and after several hours work I have figured out the problem.
The reason that this seems to occur after a year or so is, I believe, related to the fact that the housing in which the white button sits is made of thermoplastic and is not dimensionally stable. For the button to work properly both the circular hole in which the button sits and the button itself must be circular and the button must be very slightly smaller in diameter than the housing. If either of these are slightly distorted the button will stick.
The other thing to know is that when the cradle is off the chassis the button will always be in the 'in' position. What pushes it out is the pressure of the part of the chassis on which the cradle sits when you push the cradle onto the frame (you can demonstrate this by getting a screwdriver or thin dowel) and pusing down on the plate within the socket on the cradle that sits on the chassis - when you do this the button will pop out and when you take the pressure off it will pop in again).
If when the cradle is attached to the chassis the button is not out, give it a few quick sharp presses on one side to make sure it isn't binding on the plastic within it sits.
This should releases it.
The cure? You need to dissamble the button assembly and spray some silicone lubrication or similar and make sure the various parts are working smoothly. Also you need to check to see if the white button is binding on its black housing. If it is, then carefully use some wet and dry paper or similar abrasive on the circumference of the button until it stops binding
Having figured out how this works I have to say that I consider the mechanism to be a very poor one considering the price that is charged for Bugaboos. If they took a little more care and made sure the button and housing wouldn't distort with age and bind, the problem wouldn't exist.
Hope this helps. .
Aug 11, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
220 people viewed this question
Top Bugaboo Baby Gear Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
