Toshiba Satellite A75-S209 Notebook Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need inverter part number for toshiba satellite A75 s209 psa70u-09700e. Tnx
Anonymous
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
81
Questions
0
Helped
12338
Points
255
How do I do a complete restore on a Toshiba Satellite A75-S209
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Some of my keys are printing differently in my Toshiba Satellite A75 S209 Laptop
You need to turn off the Number Lock. Press the ScrLk/NumLk key it is located near the F11 key. When you turn off the number lock the NumLk LED light will also switch off and you will get letters instead of numbers.
Toshiba A 75
The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
LCD screens and Inverters are available from this WEB site.
www.lcdparts.net
Wanted Toshiba Satellite A75-S209 17"
I had an old thinkpad that i needed a screen for...i believe I ordered it off ebay...and it was under 100 dollars...go to ebay and try it
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
2answers
A brobblem with my chrger
Here is the replacement Toshiba Satellite A75-S209 A75-S2112 AC Power ..
Part number: PA3290U-2ACA, or PA3290E-2ACA
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
