It's very common when installing Windows 7 for you to get to the Windows logo or blue windows screen and it be blank and you sometimes have to wait for anything up to 15-20mins before the installation options appear, unsure why this is but make sure you allow 30mins on that blank screen before righting it off... You also need to decide if your setting up a dual boot system if you already have XP on their, if you want to keep both then select dual boot when installing. Sorry it's not an answer but waiting 15-mins or so may give u the answer, had that happen lots of times with win7
I am not sure which OS you have installed, any how if you have installed XP on your notebook then us the provided URL to download and install the audio drivers:
Installation Instructions ------------------------- This driver can be installed with the Software Installer, or by following the instcructions in the next section.
In both cases, please confirm that the driver is correctly installed, by determining the installed driver version as described below.
Clean installation: 1. Start Windows and log on with the user ID authorized as an administrator for Windows 2000/XP. 2. Extract this package onto the hard drive. 3. Click Start, then click Run. 4. Type C:\DRIVERS\WIN\AUDIO\SETUP.EXE in the Open box and click OK. 5. Follow the instructions on the screen. 6. Click Finish and Reboot the system when prompted in order to complete the installation.
Upgrading or reinstall: Note: Remove any previously installed driver using the uninstall step in the next section.
1. Start Windows and log on with the user ID authorized as an administrator for Windows 2000/XP. 2. Extract this package onto the hard drive. 3. Click Start, then click Run. 4. Type C:\DRIVERS\WIN\AUDIO\SETUP.EXE in the Open box and click OK. 5. If the dialog box appears, select Reinstall or Update and then click Next. 6. Click Finish to reboot the system and complete the installation.
Unattended installation (Windows 2000/XP): Note: This is for system administrators' use only.
In the step 4. of the Clean Installation procedure type C:\DRIVERS\WIN\AUDIO\SETUP.EXE -S -SMS in the Open box and click OK.
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location. Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
External monitor (CRT display)
Computer display and external monitor (LCD + CRT display)
Computer display (LCD)
Notes:
For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
You maybe able to get the video driver from IBM/Lenovo WEB site.
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it’s file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:drivers Then install the various drivers from this folder (run the set-up file).
hmm. It seems like you have a corrupted operating system installed. as you have said that after you have installed it wont go in on windows. try installing win xp again and if problem still persist find another windows xp installer and fresh install it 2 your pc
