Reset your SNT-V704:
Open it up and press the reset button on the main PCB 5 times while it is on. You can find the reset switch lower right corner when the front facia faces the ground. This worked for me.
I know this is an old question but I haven't found this solution on the net so let me know if it helps anyone.
SOURCE: Sony SNT-V704
If your unit keeps crashing this could be a sign of over heating. There is a way to test if it is an overheating issue and that is as the unit is playing use a hot air gun to raise the temperature and trigger the problem once the bad component is found replace it.
